Old 03-13-2007, 08:44 PM   #1
ldanny
ldanny's Avatar
Taking the bed off
this weekend wondering if ther was any tips or tricks that i need to no about, dont think there would be but hey u never no
ldanny is offline   Reply With Quote
Old 03-14-2007, 06:39 AM   #2
ChadMorris
Newbie truck Rebuilder!
Re: Taking the bed off
Lots of WD-40 if your was rusted like mine.......And a good die-grinder .....
"Old Blue" 1964 GMC Fleetside in pieces
350 TPI with 700R4 tranny now installed( well kinda propped in place until the tranny crossmember is bolted in !!!!!
1995 Toyota 4runner , 197,000 miles and going...
2007 Honda Odyssey Van (Wifes car)
ChadMorris is offline   Reply With Quote
Old 03-14-2007, 08:10 AM   #3
hewlett2002000
hewlett2002000's Avatar
i did something nobody else has done. i took the bed off of my truck in less than 5 minutes. and dident hurt it. used a grinder and cut the bolts, the two of us lifted it off and set it on its end in less than 5 minutes. beat that!! lol im just messin with ya. good luck
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 03-14-2007, 07:13 PM   #4
ldanny
ldanny's Avatar
haha well i think im going to grind the olts off since im gooing to buy new bolts anyways
Old 03-14-2007, 07:37 PM   #5
sighlurr
______________
sighlurr's Avatar
If you're removing the actual bedsides from the bed floor itself, look for spot welds on the rear of the bedside connecting the floor - where a roll pan would mount. Those kinda snuck up on me as I muscled a side off, costing me a complete new side. Don't want ANYONE to make this same, very dumb and costly mistake!
sighlurr is offline   Reply With Quote
Old 03-14-2007, 10:24 PM   #6
ldanny
ldanny's Avatar
im taking the whole bed as one piece the wood too
Old 03-15-2007, 03:44 AM   #7
harry
harry's Avatar
just took my long fleetside off tonight,one guy on each corner took 5 mins to lift off and sat it on three 44 gallon drums,already had bolts undone though
cheers
harry is offline   Reply With Quote
Old 03-15-2007, 10:50 PM   #8
ldanny
ldanny's Avatar
cheers
did u take it off with the wood in it and how heavy was it give or take
Old 03-16-2007, 02:10 AM   #9
harry
harry's Avatar
four of us lifted it easily and walked with it ,but didnt have original timber in it so may have been lighter
Old 03-16-2007, 04:32 AM   #10
harry
harry's Avatar
heres some pics
Old 03-16-2007, 09:20 AM   #11
Chevy Fleetside
Chevy Fleetside's Avatar
I took mine off by myself... Just got some tie downs, put one in each corner and hooked up my engine hoist.. I started lifting and adjusted the tie downs as i went..
Chevy Fleetside is offline   Reply With Quote
Old 03-16-2007, 11:59 AM   #12
chevy_mike
Never Ending Projects
chevy_mike's Avatar
With as rotted out my wood is, I'm surprised it hasn't just fallen off yet.
chevy_mike is offline   Reply With Quote
Old 03-16-2007, 02:28 PM   #13
ldanny
ldanny's Avatar
well theres going to be two of us taking it off with the wood in it ill post some pics after i get it off
Old 03-16-2007, 02:41 PM   #14
msgross
msgross's Avatar
When i took mine off my 68 I had already removed the wood. most of the bolts came out but I had to cut the others and were they tough. Not sure if they are grade 8 bolts but I went through plenty of saw blades! Finally torched the last one off... Good luck.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 03-18-2007, 02:15 PM   #15
jgrh64
Prestige member Old Farts Club
jgrh64's Avatar
can you change the bed wood on the truck or do you have to take off the bed ? how hard to change the wheel wells - any hidden bolts ?
Hey sombodys gotta do it!
jgrh64 is offline   Reply With Quote
Old 03-18-2007, 11:08 PM   #16
ldanny
ldanny's Avatar
well its off we ended up getting two come alongs on each side and raising it up and driving out from underneath it it went real smooth on the very back cross member u can see the numbers c1534 which i think is the code for c-10 it was pretty cool to see the factory wrightings ill post the rest on the next post
Old 03-19-2007, 12:52 AM   #17
Sillyoldman
#16876
Sillyoldman's Avatar
Last two times I did it by myself. Just cut the bolts, removed it. I stood it up to make the work easier on my back. Then I used a hammer to knock out the rotten wood. Once the wood was gone the bolts were revealed and cut from the side. It took an afternoon of solid work.
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 03-22-2007, 06:36 PM   #18
jgrh64
jgrh64's Avatar
so I take it- yes you do have to remove the bed to change wood . What about the wheel well removal ????
Old 06-02-2007, 01:21 PM   #19
LILRED66
LILRED66's Avatar
This method works great if you are working alone.
LILRED66 is offline   Reply With Quote
Old 06-02-2007, 03:59 PM   #20
salazar44
65 - Chevy C10
salazar44's Avatar
Somebody once asked this question if they should install the wood while the bed is off or on. The answer was (and I forgot who answered) to install the wood while the bed is ON the truck. The reason is so you can make sure the bed is squared. If all the wood is tightened down when the bed is off, there may be tweaking. This will affect your ability to match up the holes when trying to put the bed back on.
This made since to me. Somebody probably learned this the hard way.
VIC
One Repair Leads to Another!
http://vix65chevyc10.blogspot.com
salazar44 is offline   Reply With Quote
