Old 03-13-2007, 09:03 PM   #1
jcfoote60
Active Member
jcfoote60's Avatar
Turbo 350 question
Guys I have a TH350 starting to slip in 3rd gear after it is driven for a while (say 15 minutes or so). I checked to make sure the fluid is good, not burnt and full so nothing apparent so I guess I have clutches on their way out..so the question I have is this. my truck is a 1972 4x4, if I want to pick up a good used one, what is the span of years that they made the TH350 trans with the correct adapter to an NP205 transfer case?
PS- I service the tranny not very long ago, changing the filter, gasket and refilling with fresh fluid. I did notice quite a bit of slude in the pan...bummer.
Thanks for your help!
Jim
jcfoote60 is offline   Reply With Quote
Old 03-13-2007, 09:11 PM   #2
1969k10stepside
Re: Turbo 350 question
Any th350 for a 4x4 will work.I took a 2wd tranny and converted it to a 4x4 th350 too.The adapter un bolts from both the t case and tranny,just keep it on the t case and bolt the new tranny up to it.
1969k10stepside is offline   Reply With Quote
