Old 09-01-2002, 10:38 PM   #1
bigcarguy
Finally a Bulldawg
bigcarguy's Avatar
Rear control arm bushings: pressed in or not?
Pretty much just what the subject says. Am I gonna need a press to put the rear control arm bushings in, or will they just slide in? The same question applies to their removal, also.
Ah yes, the college life. School all morning, work all night, study when ya can. Uh...
bigcarguy is offline   Reply With Quote
Old 09-01-2002, 11:19 PM   #2
Kas68c10
Kas68c10's Avatar
Mine slid in,with a little persuasion (propane torch, hammer), I had the poly bushings though, stock I think are different
1968 SWB Stepside, 250,pwr disc brake and tilt pwr steering, 5 spd tranny, HEI,Accel coil,K&N filter,Seat from a later truck with built in seatbelts, front and rear sway bars, moved gas tank to under the bed, headman hedders, new chrome bumpers,one wire alternator,Weber k550cub carburator...WORK IN PROGRESS, Freeland MI , Just bought a 72 Jimmy!!!!!!!!!!!
Kas68c10 is offline   Reply With Quote
Old 09-02-2002, 07:35 AM   #3
Cheyenne Super
trailing arm bushings
i had to press mine out and in. even then the end of the arm wanted to squeeze together.
1971 Cheyenne Super
Soon to be converted to '68 front clip.
Efland, NC
Cheyenne Super is offline   Reply With Quote
Old 09-02-2002, 09:44 AM   #4
slam33
slam33's Avatar
Use a propane torch to melt the old one and just push them out, get the poly ones they just slide in. Be sure to use all the grease they come with, it's a great set up
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 09-02-2002, 09:58 AM   #5
Gee_Emm
There is a metal sleeve that is pressed in that can be replaced. I basically set mine on fire with a propane torch, it didnt seem like the old rubber would come out any other way being all stuck to the sides of the metal sleeve. If you do it this way do it outside though :p
Gee_Emm is offline   Reply With Quote
Old 09-02-2002, 10:14 AM   #6
Cheyenne Super
something else
you can run a drill bit through the old bushing to help it come out easier
1971 Cheyenne Super
Efland, NC
Old 09-02-2002, 12:57 PM   #7
minibike
minibike's Avatar
The drill bit is a good idea...wish I would have known about it 6 months ago!
69 SWB
LT1/4L60E
www.classicplace.com
minibike is offline   Reply With Quote
