Old 09-01-2002, 11:21 PM   #1
HotRod929
HotRod929's Avatar
Location: Bondurant, IA but in Worcester, MA for school
Fried My Battery Cables Today.
Well I got my new headers installed so my buddy and I decided to take my truck for a spin with open headers and see how many car alarms we could set off. Well it all started out good untill my truck tied and started to smoke terribly. We oipend the hood up and found both my battery cables fried and melting. What had happened was when we put the pos. cable back it was touching the header so it melted and then compleated a citcuit with the neg. and BAM a huge short circuit that melted the terminals off the battery. So the lession of the day is to check your cables and make sure they do not touch your headers. So I have to go get new cables tomarrow and put em on. I love the way it sounds with open headers. Oh and by the way we set off FIVE car alarms within like 3 blocks. It was great.
HotRod
1970 Chevy C-20
350 V-8
Turbo 350 w/ shift kit
Dana 60 w/ 4.10 gears AND Powr-Loc POSI
New Additions:
Summit Headers
135amp alternator
Proform HEI
Edelbrock 1406 600cfm carb
Sunpro Tach
Powr-Loc POSI
Edelbrock Performer RPM Intake
MSD 6A Ignition Box
AIM: HotRod929
Visit My Site: http://1970chevy.netfirms.com/
HotRod929 is offline   Reply With Quote
Old 09-02-2002, 07:14 AM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I had a similar problem, but it was the battery wire from the alternator to the battery that was the problem. We had put a new intake on the engine, and the wiring harness was relocated slightly during the process.
After a few trips to/from work, the covering on the wire had gotten sufficiently thin and shorted out one September morning about two years ago. I had just started the engine, which then died. It knew it wasn't a normal shut down. Smoke started rolling out from under the hood. Not a good feeling. I opened the hood and saw a red glow all across the front of the radiator. It was the lighting harness. One wire was glowing really good. I grabbed it with my right hand and pulled it apart....I didn't have a wrench or gloves...the fire extinguisher didn't help. Oh, burned the crap out of my fingers, but it healed.
Believe it or not, but I have full coverage on my '69, and I made about $150 off of the deal, even after buying two new harnesses, paint and wire looms. Turns out the adjuster was sympathetic to old cars, and knew how to make it possible for me to do my own work and get paid for it. This was after my $50 dedeuctible. I guess I got paid for my pain and suffering fingers, huh?
Glad it wasn't worse....it could have been. So, check all of your wiring and be sure it isn't anywhere near the headers.
Member Nr. 2770
Old 09-02-2002, 09:46 AM   #3
palallin
It could have been worse another way: see my "Exploding Battery" thread. . . .
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 09-02-2002, 10:34 AM   #4
mt Al
Similar thing happened to me, but it was a bad starter. When I was cranking it over I got to watch the lead melt into drops off of the cable clamp, sparks fly, etc.
No car alarm setoffs for me, but thanks for sharing the results of your test recon mission.
'72 GMC 1/2T 4x4 1500 Super Custom pickup (current)
past rides were:
'70 Chev 2wd farm truck
'71 GMC 2wd 1/2T 402 nice!
'72 Chev 2wd 1/2T 396
'72 GMC 3/4T 4x4 2500 Super Custom suburban.
Bozeman, Montana
mt Al is offline   Reply With Quote
Old 09-02-2002, 10:40 AM   #5
racedvl
racedvl's Avatar
I had the same thing happen to me, after changing my starter. But, I was in the middle of nowhere. Plus I also ended up putting a hole in my header where it melted the pos. cable, and made contact. This was at the end of winter. I'm still using this fix....LOL.
racedvl is offline   Reply With Quote
