Sitting on the tires
First time in 2 years she's sitting on the tires. Just mockup rims and junk tires. As you can see the doors are next. I just finished rounding the bed corners and you can see my column drop that will be finished to look like the vintage Hildebrand 4 hole gage panel to go under the dash. IDIDIT column and plain vinyl covered wheel. Enjoy.
Certified Car Nut
Re: Sitting on the tires
My friend round his bed corners its a nice little mod. He used some 90 degrees exhaust tubing. Your truck is looking nice and I know what you mean about having it sit on all 4's, it makes you feel like you are getting stuff done. It looks like you have some nice work space I wish I had it. Nice work man
Yellow truck club
Looks good I like the bed mod. Are you going to put the vent windows back in or going 1 piece windows?
Brian .. ![]()
................................................................ Brian ...... ![]() My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW ![]() ![]() ![]() ![]() PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
I like It!!!
![]() Join Date: Mar 2005
One of my favorite trucks on this site. It's going to look awesome whenever it's finished. What do you have in mind for paint, wheels/tires, etc? Also, I really like the bed corners and the extra storage compartments in the lower section of the doors (just kidding....)
________ HERBALAIRE REVIEW Last edited by chevyrestoguy; 02-18-2011 at 11:07 AM. |
Looking really good Bob! I to like the bed corners and I'm planning on having the same thing done to mine. If I may ask, how did you get the rounded corners? Did you use 90 degree exhaust tubing like Kabwe's friend did?
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 |
You guys are too kind!
![]() At first I just rounded the corners in one plane but the rear corners didn't match the top of the tail gate so I cut and welded to make them rounded in that plane too. I left the front alone so they matched the top edge of the front of the bed (square). Hopefully the pictures show the story. Yes I have a two car garage but my wife's car [U]must[U] be inside every night so I have to keep it clean and organized. Shop vac and a good broom are used alot. I'm going with one piece windows from Brothers my only worry is if I chop the top then I'll need new side glass. Because of the shape of the window (parallelogram) I think the window slides up and down in the lower door at a angle and when it reaches the top it pivots level. If the glass is the stock height it can't pivot...I'll figure it out when I do the doors. As far as plans for paint etc. It will depend on money. (Doesn't everything?) May have to live with primer for awhile. I'm going for a mid-60's look so I want old school mags like non polished ETs 17"x7" in front and 17"x11" in back. I need as much back space in the front as possible so I can get full lock with it slammed. Rear tires will be 29" tall and fronts will be 26". So far I have a Fat Man front end with shock waves and a No Limit four link in back with a 3:50 geared posi 9" with shock waves. Willwood 12" discs all around. The frame is fully boxed. Front and rear sway bars. 454 (at least) with TH400. Sanderson headers and 2 1/2" pipes with a X pipe. I've got a IDIDIT column and a Grant wheel. I just picked up a B&M Mega shifter for $100. The bed is all steel with a louvered tail gate and hidden latches. I made my own design offset master cylinder/brake pedal. Future mods wil include pie-cut hood and sectioned front bumper. Haven't decided on the rear yet. ...and a 3" chop. Still have to build motor, get trans rebuilt, drive shaft, gas tank (under front of bed), air system, wiring kit, etc. I have more pictures if you want them. |
Yellow truck club
Great thread on your truck.
Do you have any 4-link pics/rear end as I'm getting ready to do my truck with 4-link and bags. Brian ... ![]()
Four link pics. I started with the frame sitting on the axle. Actually welded to the axle once I got it positioned. I will have 3" of downward travel at the back. Getting the panhard bar to be level at ride height was tricky.
Good work. My '54 bed ends are a similar finish, like this one I saw at a local show and shine.
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674 My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost 1960 (400/T350/?) Apache 10 short/fleet side-big window 1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4 2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB Doing my part to warm the globe ![]() |
what rims /bolt pattern are they, old z-28 rims?
They look like '87 IROC wheels.
#13 |
tiggerstoy
it looks great, i love the frame , did you go with new fenders? or are they done and ready for paint,i used patch pans on my front, might buy new for the rear. um...how much of a chop did you go with for the firewall/floor(trans clearence?
#14 |
Yes, they are Z28 or IROC wheels, 8"x16". I have the rears in the front because they have more offset. I bought all new fenders and steps. The firewall and floor are from Direct Sheetmetal with a 4" set back. I added pics of the wheel tubs I made from a pair of trailer fenders, the bed bracing and floors, and the tailgate latch.
#15 |
Certified Car Nut
I only have one word to say. NICE
#16 |
tiggerstoy
thanks, your truck sure is looking good, keep up the good work.
#17 |
how did u get the Z28 wheels to bolt up..... are the hubs 4 and 3/4 in pattern?
#18 |
Yes, they are 4 3/4" B.C.. Currie axles in back and the Fatman kit (2" drop) up front. I thought I was going to have currie shorten my old axles but I had to buy new ones to get everything to match up with the Wilwood rear brakes...which I already bought.
#19 |
Sb 400 club
wow that is some nice work you have done there. That is gonna be one sweet truck when it goes for paint
![]() ![]() 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed ![]() 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
#20 |
Nice work Bob!
