Old 03-14-2007, 07:22 PM   #1
munroe
munroe's Avatar
how wide can i go?
how wide of a whell can i fit on my seirra with the stock wheel tubs? i want to run 15x8 rally wheels in the front and 15x10 or, if they will fit 15x12 rallies in the back. im pretty sure the 15x12s wont fit, but will the 15x10s fit without the tires sticking out past the fenders? i tried a search and drew a blank. thanks
87 chev wrangler
munroe is offline   Reply With Quote
Old 03-14-2007, 08:39 PM   #2
bigblock73
yeller
bigblock73's Avatar
Re: how wide can i go?
15x10's will fit no problem, here is my truck with them on the rear.
15x12's would be a close fit, and would require a lot of backspace to make work...even then, not sure the tires would clear the inner fenders if they did fit.
bigblock73 is offline   Reply With Quote
Old 03-14-2007, 08:42 PM   #3
munroe
munroe's Avatar
thanks. the 15x10s look great on your truck, and if they fit ill go with them. what size tires are you runnin on them? any shots from the rear of your truck?
87 chev wrangler
Old 03-14-2007, 09:27 PM   #4
bigtruck81
wow Jeff, Yeller is looking good! been a while since i saw one of your updates.
bigtruck81 is offline   Reply With Quote
Old 03-15-2007, 02:28 AM   #5
84slopwaggin
84slopwaggin's Avatar
I would love to run 10's in the rear with 275/60 and 8's in the front with the same tire size, but I don't know how that would look on a LWB. Oh and you can't rotate the tires with the staggered fit. That's my hangup. I'll more than likely just do 8's all around.
84slopwaggin is offline   Reply With Quote
Old 03-15-2007, 07:38 AM   #6
piecesparts
Parts and more parts
piecesparts's Avatar
The whole trick is what backspacing you have on the wheels. You can order a set that has more backspacing and gain the room under the fenders.
piecesparts is offline   Reply With Quote
Old 03-16-2007, 09:39 PM   #7
77-383 Step
I have a step side with 15X10 rallies and 325-50-15's on the rear. only have about 1/2" clearance. Buy the way, I have a 4/5 drop.
77-383 Step is offline   Reply With Quote
Old 03-17-2007, 12:16 AM   #8
strokd 84
strokd 84's Avatar
You could compromise and go 9's all the way around. That way you still get the look/traction of 10 and still get to rotate your tires...
1984 Silverado SWB
Second Owner
Featured in Custom Classic Trucks May 2013
http://www.customclassictrucks.com/f...let_silverado/
strokd 84 is offline   Reply With Quote
Old 03-17-2007, 01:34 PM   #9
Grande Rojo
paper or plastic?
Grande Rojo's Avatar
I've got 20x12's in the rear of my stepside. 12" wide rims will fit.....Its all in the backspacing and tire width.
Grande Rojo is offline   Reply With Quote
