Old 03-14-2007, 07:50 PM   #1
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
Is This High Temp Paint any Good?
Any one ever use this on Manifold's & what were the Result's?
Thanks,, Rick
toomanytoyz is offline   Reply With Quote
Old 03-14-2007, 09:52 PM   #2
65-72 chevytoys
65-72 chevytoys's Avatar
Re: Is This High Temp Paint any Good?
Never used that brand I have used the duplicolor Hi Temp paint but it should work just fine. Just make sure its clean before paint. Prep work is the key.
2004 Chevy Silverado 1500LS SWB 5.3L
2004 Corvette Z16 #770
Wish I had not sold 72 blazer
65-72 chevytoys is offline   Reply With Quote
Old 03-14-2007, 09:57 PM   #3
cfoust3
cfoust3's Avatar
I think thats the stuff I used, and it worked just fine. Just make sure you degrease your motor first, it there is dirt the paint will not bond and will flake off.
Let me tell you what Melba Toast is packin' right here, all right. We got 4:11 Positrac outback, 750 double pumper, Edelbrock intake, bored over 30, 11 to 1 pop-up pistons, turbo-jet 390 horsepower. We're talkin' some ****in' muscle.
-Wooderson
From the movie Dazed and Confused
cfoust3 is offline   Reply With Quote
Old 03-15-2007, 08:23 AM   #4
For best results,blast first.
Old 03-15-2007, 10:26 AM   #5
snj8198
snj8198's Avatar
yup!
snj8198 is offline   Reply With Quote
Old 03-15-2007, 12:46 PM   #6
jkaylor68gmc
jkaylor68gmc's Avatar
No! I would recommend normal car primer, paint and clear.
jkaylor68gmc is offline   Reply With Quote
Old 03-15-2007, 01:26 PM   #7
Frizzle Fry
Frizzle Fry's Avatar
...and if you get any oil on the exhaust manifolds or headers after painting, be sure to clean it off before running the engine because it can stain bad.
Frizzle Fry is offline   Reply With Quote
Old 03-16-2007, 08:25 AM   #8
68Stepbed
68Stepbed's Avatar
The secret to painting exhaust manifolds:
1. sand blast
2. paint with a very light coat, just enough to put color on it. NO PRIMER
3. If you have access to an old stove, bake them at 400 deg. for about 30 min. If not install them and run the engine for short periods of time until well baked to the metal.
If you don't sand blast them, paint will never stay on them.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
