Old 03-14-2007, 08:36 PM   #1
72shadetree
KEEP ON TRUCKING
72shadetree's Avatar
69 sb to bb help
when we got the 69 it had a sb on 73 and up frame towers/motor mounts that are in the 6cyl position.it sits so close to firewall the hei has to be put in after motor.will a 402 bb fit this way or do i need to move the towers to the v8 position.i konw it will be a tight fit but would like to leave it sitting back if i could.
thanks to fuel pump going bad the sb is really clean inside.guess all that gas cleaned it up good before it took out the bearings.lol
72 cheyenne 2wd lwb
71 k20 sons
bassett va
72shadetree is offline   Reply With Quote
Old 03-14-2007, 09:25 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: 69 sb to bb help
shadetree,
You might give this thread a read..... It might provide a little insight.
http://67-72chevytrucks.com/vboard/s...el#post2046975
LockDoc
Leon
Old 03-15-2007, 11:47 AM   #3
72shadetree
KEEP ON TRUCKING
thanks that helped some
will a bb fit on 72 bb towers but in the 6cyl position.i have the 72 mounts was going to use em for another project.the truck already has the 73 and up mounts which are real close to the 72 mounts
72 cheyenne 2wd lwb
71 k20 sons
bassett va
Old 03-15-2007, 03:48 PM   #4
Yukon Jack
Post Whore
Yukon Jack's Avatar
The sbc's in the the 4wd's are in the 6 cyl position and most people have firewall issues when they swap in a bbc so I'm assuming you likely will too. I'd move it forward if it were me.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 03-16-2007, 12:04 AM   #5
72shadetree
KEEP ON TRUCKING
ok thanks
72 cheyenne 2wd lwb
71 k20 sons
bassett va
Old 03-16-2007, 02:29 AM   #6
combustion
Originally Posted by LockDoc View Post
shadetree,
LockDoc
thanx to these guys i was able to finish my swap. here are pictures
how it started
the engine
when i first droped it
onced finished
all i had to do was attach the motor to the tranny and let it drop WITH THE MOTOR MOUNT TOWERS ATTACHED TO THE MOTOR mounts, once the engine was siting on the towers i just modified and tweeked them to clear the bb stock exhaust manifolds and fit the chassis properly
If it`s 3.73 ratio you will spint the wheel 100 times to the driveshaft`s 373 times.Or,if you`re lazy,you could just spin the wheel once and the driveshaft will spin 3.73 times.Or, 3 and 3/4 turns.And if you`re real lazy,I can sell you a tab for whatever ratio you want.
Or,you could read all the suggestions and try those.It`s been well explained,I think,already.
combustion is offline   Reply With Quote
