03-14-2007, 10:39 PM | #1 |
69?'s
i just bought 2 69's 1 custom 10 and 1 custom 20 with leaf springs and a dana rear 350 th 400 1st ? what would be standard gear ratio if none is listed and ?2why do some door panels have the bow tie and some not , is that a year thing and they wer changed in one truck, sorry no pics yet
common sense isn't so common anymore |
03-15-2007, 07:54 AM | #2 |
Re: 69?'s
with the 3/4 ton and dana rear, i think it should be 4.10. at least, mine is and i have no other listed ratio
1969 GMC 3/4 ton, 307, 4-speed NP435GL, DANA 60, 4.10, HD rear leafs, manual everything, leaking oil and water. Now rocking 383, NV4500, power steering, power brakes. Finally undergoing restoration. |
03-15-2007, 07:58 AM | #3 |
Re: 69?'s
Ratios are never listed.The bowtie was`69-only.
03-15-2007, 01:19 PM | #4 |
its all about the +6 inches
Re: 69?'s
the69 was a one year only door panel, and there are 2 versions as you've seen. I can't remember which way it goes, but one is early, and one is late. I have one of one style, and one of the other style on mine.
i *THINK* the bow tie is early, and blank is later... but I could be wrong on that... I have a 50/50 chance. |
03-15-2007, 01:20 PM | #5 |
Re: 69?'s
oh, almost forgot the gearing Q...
a 1/2 ton... small block and auto, with no gear listed, should be a 3.07 A 3/4 ton equipped th4e same way, would be a 4.10. |
03-15-2007, 05:16 PM | #6 |
Re: 69?'s
I have a D60 that is a 3.54.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
03-15-2007, 05:32 PM | #7 |
Re: 69?'s
that would have beena big block truck
03-15-2007, 07:03 PM | #8 |
Re: 69?'s
thanks all was hoping i had the 3.54 ratio becausei;m thinking this is the truck needing the 500 caddy
03-15-2007, 07:14 PM | #9 |
Re: 69?'s
you'll want better gearing for a cad.... trust me
