Old 03-14-2007, 11:02 PM   #1
76bonanza
76bonanza's Avatar
Harmonic Balancer Repair Sleeve
Anyone use these? I have a small leak from my timeing cover from around the shaft? Are they easy to install and do they work?
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 03-14-2007, 11:14 PM   #2
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
Re: Harmonic Balancer Repair Sleeve
Temporary fix only IMO. I have used one once with no issues. If your planning on keeping the truck for the long haul 76bonanza then invest in a new balancer. My thinking on this is after many miles if the sleeve wears out or through it wont be a small leak It will leave you stranded wherever it decides to go by tearing the seal. Just my .02
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 03-14-2007, 11:49 PM   #3
kelsfine69
18 Till I Die
kelsfine69's Avatar
Speedy sleeve ...sure. Used them alot and never had a problem. Works on pinion yolks too. New seal and a sleeve you wont have a problem
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 03-15-2007, 06:58 AM   #4
cduster
I have used a few of them with no problems at all.
Good Judgment comes from experience.
Most experience comes from bad judgment.
cduster is offline   Reply With Quote
Old 03-15-2007, 07:13 AM   #5
mrein3
mrein3's Avatar
I've used both the sleeve and an "offset seal". The offset seal starts cutting a groove somewhere else on your balancer.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 03-15-2007, 07:36 AM   #6
piecesparts
Parts and more parts
piecesparts's Avatar
I have had engines that had them on there and they worked for over 50,000 miles. They are a good thing to save some dough, but nothing replaces a new Harmonic balancer.
piecesparts is offline   Reply With Quote
Old 03-15-2007, 08:00 AM   #7
Huck
Huck's Avatar
I've used them and will continue to use them--they are cheap, quick and easy fix that seems to last about as long as the original balancer!
Huck is offline   Reply With Quote
Old 03-15-2007, 09:47 AM   #8
Yukon Jack
Post Whore
Yukon Jack's Avatar
Put one on the bbc before I swapped it into the K20. No drips so it seems to be working just fine.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 03-15-2007, 09:54 AM   #9
76bonanza
76bonanza's Avatar
I am a learn as you go mechanic and I can say I have never had a balance off. So what you guys are saying is the balancer has a sleeve that goes over the crank and it is that sleeve that penatrates the seal in the cover?
I think I understand now. A few questions. To put on the sleeve I pull the balancer put sleeve over balance hub then press balancer back on? How can I tell if it is the seal or the balancer? I am looking for an easy fix right now. And to replace the seal I have to pull timing cover and water pump and all right?
1968 c10
lowered 3" 4"
Old 03-15-2007, 12:04 PM   #10
RACINJASON22
GEARHEAD
What happens is that the seal actually wears a grove inth the balancer hub creating a leak. You are correct in pulling the balancer/ sleeve goes over hub, new seal in cover and reinstall. You do not need to remove the water pump or timing cover to perform this task. You can replace seal with the timing cover on. As for telling which one is bad It depends on if the balancer hub seal mating surface has a low spot in it. As stated before I have also used these once with out problems. Definatly a good quik fix and they seem to work well from what everyone else said. I just recomend the balancer for the long haul. While you have the balancer off check the rubber dampening ring on old balancer this may help you make up your mind which way to go also. RJ22
Old 03-15-2007, 12:28 PM   #11
76bonanza
76bonanza's Avatar
So what you are saying is that I can replace the seal in the timeing cover and put on a brand new balancer without removing the timeing chain cover? So the procedure is about the same for ethier fix just cheaper one way. I am not overly concerened with price just time.
Any tips on looking for a new balancer? I have a mild 355 about 330hp no track time about 40 miles a week.
Also it drips about one drop every day I drive it. Think it will be ok for another 6 months or so? Untill I get up the money for new balancer and all?
1968 c10
lowered 3" 4"
Old 03-15-2007, 12:38 PM   #12
RACINJASON22
GEARHEAD
Yes you can do this job with out removing the timing cover. Here's a good stock replacement from summit for $53.95 which is the way I would go or they go up from there. You could go even cheaper probably from your local auto parts store maybe a little.
http://store.summitracing.com/partde...5&autoview=sku
Old 03-18-2007, 09:26 PM   #13
71 lowrider
I use a speedy sleeve on every chevy engine I rebuild. Have used them for years,never had a problem.If the only problem with your damper is a groove,I dont see why you would spend the $$ for a new damper. I havent done one lately,but I am sure you could do a sleeve and seal for around $20.
71 lowrider is offline   Reply With Quote
Old 03-18-2007, 09:40 PM   #14
76bonanza
76bonanza's Avatar
one other question looks like I will have to remove radiator to remove balancer is this true?
1968 c10
lowered 3" 4"
Old 03-18-2007, 09:49 PM   #15
RACINJASON22
GEARHEAD
Might be a good idea they don't take the bumps too well. If your carefull the puller should fit in there but, I would suggest it for the job at hand. RJ22
Old 03-18-2007, 11:34 PM   #16
jimfulco
Be sure you remove any nicks or burrs from the balancer before installing the sleeve. Even a tiny little bump will screw up the sleeve when you try to install it. Use some 400-grit wet-n-dry sandpaper with light oil or WD-40 for lube. I just wrap some around the hub and wrap my thumb & forefinger around it and twist it around until it cleans up. Bit nicks will need a file or stone. Clean it off, loctite it, and tap the sleeve on GENTLY with a block of wood.
jimfulco is offline   Reply With Quote
