horn relay
Hey anyone know where the horn relay is on a 73. I'm assumming that the horn button is a ground and when depressed it makes the relay send power to the horn. thanks for any help Tyjoja
Re: horn relay
It under the dash on the drivers side around the fusebox area. I cant remember if it's plugged directly into the fuse box or if there's some wires going to it, but it's there. There are 2 larger objects like that under there, the flasher for the turn signals and the horn relay for the horn if I remember right, so you should be able to find it.
Re: horn relay
thanks a lot pyro, I appreciate it. Tyjoja
| Bookmarks |
