View Poll Results: which route is the best
Use just the parts needed off the burb 1 3.85%
swap out entire crossmember, and drill out the two holes 23 88.46%
swap out entire crossmember and leave the two bolts out that don't line up 2 7.69%
bang my head against the wall!!!! 0 0%
Voters: 26. You may not vote on this poll
Old 03-15-2007, 01:47 PM   #1
zeitlerusmc
zeitlerusmc's Avatar
Need everyone's opinion
I have a 1987 suburban as a donor truck. I read the sticky about leaving the front crossmember in place and just taking the a-arms and spindles off, but looking at the front end that seems like more work than just unbolting both front crossmembers and swapping them out, both trucks have no motor in them and my 63's front clip is just sitting on the frame so room and clearence is no problem. what do you guys think?
A. remove just the parts needed from the burb (sticky )
B. swap out the hole sha-bang including power booster, and master cylinder
C.
D.
zeitlerusmc is offline   Reply With Quote
Old 03-15-2007, 03:01 PM   #2
62 short step
62 short step's Avatar
Re: Need everyone's opinion
B and you'll be done.
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 03-15-2007, 07:36 PM   #3
zenish
the later crossmember has larger ubolts and other parts.plus you can be sure it will line up.
1964 c10 short step
1962 econoline van
1989 rs camaro
2006 yamaha vino 125
1975 goldwing
zenish is offline   Reply With Quote
Old 03-15-2007, 08:46 PM   #4
PrerunnerRob
PrerunnerRob's Avatar
Take everything you can off the sub, you know it all works together now!
PrerunnerRob is offline   Reply With Quote
Old 03-15-2007, 09:40 PM   #5
62ChevyStep
62ChevyStep's Avatar
thats what I did, best decision we made, also used master cylinder, proportioning valve, wiring harness, fuse block etc.
________________________
62' 3.5/5 drop SWB Fleet, PS, PB-Dsk/Drm,350/700R4
08' Chevrolet Silverado CrewCab
05'Toyota Tacoma Prerunner SR5
62ChevyStep is offline   Reply With Quote
Old 03-15-2007, 11:37 PM   #6
Captainfab
60-66 Nut
I'd swap everything, I've done a few. It isn't really that difficult especially since you have no engine in either and the front sheetmetal is basically off your 63. One suggestion though...don't get rid of the burb until you're done installing everything on the 63. That way you can verify measurements if you need to.
Old 03-15-2007, 11:46 PM   #7
zeitlerusmc
roger that gents thanks good stuff good stuff
Old 03-16-2007, 06:46 AM   #8
ChadMorris
Newbie truck Rebuilder!
Yep, I would swap the whole crossmember......makes life a little easier....
"Old Blue" 1964 GMC Fleetside in pieces
350 TPI with 700R4 tranny now installed( well kinda propped in place until the tranny crossmember is bolted in !!!!!
1995 Toyota 4runner , 197,000 miles and going...
2007 Honda Odyssey Van (Wifes car)
ChadMorris is offline   Reply With Quote
Old 03-16-2007, 03:40 PM   #9
L0WRIDE
L0WRIDE's Avatar
49 CHEVROLET 1/2 TON, 52 CHEVROLET SEDAN
62 HARDTOP NOVA
65 CHEVROLET BB LWB FLEETSIDE
90 CHEVROLET EXTRA CAB
CHEVY ONLY - NZ Chapter
http://67-72chevytrucks.com/vboard/s...d.php?t=137984
L0WRIDE is offline   Reply With Quote
Old 03-17-2007, 08:56 PM   #10
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
X2
John
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 03-19-2007, 01:17 PM   #11
shade67
Wink Re: Need everyone's opinion
I did the crossmember swap in my 66 and my 67 and the whole crossmember seems to be more heavyduty in the newer db crossmember. Also the newer one seemed a lot less crusty. I did mine with the engine in the truck though. I would highly suggest not trying it unless you have no choice!
Scott
66 chevy short step 327 4speed
67 chevy Short Fleet tpi 350 700r4
72 chevy K10 swb
01 GMC Sierra
01 Pontiac Bonneville
shade67 is offline   Reply With Quote
