horn won't shut up!
when the horn is intermittently honking --by itself--where does problem usually stem from!
R.I.P. Killer 71 10/26/07 |
Chief Honcho In Charge
Re: horn won't shut up!
Loose horn cap...splayed wire with a strand hanging out.
Bad horn relay?
1992 1500 4x4 Shortbed 1984 Ford F250 Supercab Longbed 6.9L Diesel 1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C 1971 VW SuperBeetle 1960 Wife 1984 Son 1986 Son 1989 Son Previous Trucks 1967 C10 SWB (1980-1981) 1971 C10 LWB (1998-2004) |
It's a catastrophic success.
![]() Join Date: Jan 2003
Sounds like the horn wire that runs up the column may be touching metal either on the shaft (pinched) or under your steering wheel.
The way the horn works is you have a relay ( right of the fuse box)that has power to it and the horn button provides a ground for the contact coil so for any reason it touches metal and (grounds) the horn will honk. |
![]() Join Date: Feb 2007
I experienced the same thing when I installed my Flaming River steering column. One minute it worked fine then a day later down the highway HOOOOOONk. I couldn't find the problem so yank!
as said it can be the wire in the column it's also very common with a poorly installed non stock steering wheel
![]() Join Date: Mar 2006
Ever since I put on a different steering wheel my horn has been acting up as well but it has to do with the way I reinstalled the horn ring I think. I saw a diagram somewhere on the net but lost it.
Have you guys seen the vid on the net where the fella wired his buddies horn into his brakes? Funny stuff.
1986 C10 - LWB, 305/700r4, posi, vortec heads |
