Old 03-15-2007, 02:37 PM   #1
72BigBlockSuprCustom
Advise on Wiring Harness
Hello,
I have a 72 Super Custom Camper, and I need to replace all of the wiring. Does anyone recommend what to get and where to get it?? Any help would be much appreciated.
72BigBlockSuprCustom is offline   Reply With Quote
Old 03-15-2007, 02:40 PM   #2
zacut
67 chevy SWB Fleetside
Re: Advise on Wiring Harness
I used a Painless wiring harness specifically for our trucks from Summit Racing. Wires are labeled every foot or so and some of the plugs are pre-installed. Fairly straight forward
67 Chevy C10 Short Wide
350/350 ... Front Discs ... ECE Lowered 2.5/4
Vintage Air ... Oak Bed Floor ... Painless Wiring
Brothers 1 pc Windows ... Lokar Pedals, Shifter, E-brake
Ididit Column ... VDO guages
zacut is offline   Reply With Quote
Old 03-15-2007, 02:42 PM   #3
stingray72
Red Headed Step Child
stingray72's Avatar
I got my Painless running yesterday.. I had never done ANY wiring in a vehicle before I started. If you read the instructions and take your time it's not bad. Still have to clean mine up a bit and route wires better but she's running
"Dinner, the perfect break between work and drunk"
-Homer Simpson
stingray72 is offline   Reply With Quote
Old 03-15-2007, 02:45 PM   #4
Yeah, I saw your post right before I was about to post mine! Good Job! I'll need to get one of those Wiring Your Truck for Dummies book....I wonder if Borders Books carries em! )
Thanks! I'll look it up.....
Was it as Painless as they claim???
Old 03-15-2007, 03:03 PM   #5
BigSky71
LAIDOUT
BigSky71's Avatar
I just did mine with a Painless, and it was painless I think. My truck had been apart for resto for two years, so there was no memory to go from, but I did as they suggest and laid the old harness out on the floor. Kinda arranged it how it fit in the truck which help me to identify what was what on the new harness, then began plugging stuff in.
67 2wd Shorty
Build Pictures
BigSky71 is offline   Reply With Quote
Old 03-15-2007, 03:11 PM   #6
snj8198
snj8198's Avatar
I have a universal 21 circuit harness for 67-72's from EZwiring. I have not installed it yet but I have compared it to the Painless harness. The Painless looks more complete but is more expensive. The one I got was $170 but involves more work installing. Also if you are running a set of Autometers or after market gauges Painless has a jumper harness that plugs right in but it is pricey. Last I looked Painless was about $490 and $90 for the gauge cluster harness.
snj8198 is offline   Reply With Quote
Old 03-15-2007, 03:15 PM   #7
stingray72
stingray72's Avatar
Honestly, yes it's pretty Painless. Like I said, it's tedious. Just work until you're sick of it and come back later. I kind of when through the existing harness and saw where everything was connected and then laid out the new one in the driveway to sort of figure out where everything went on the new one.
All the wires I didn't know what they were I looked up in the instructions which are written pretty well.
You don't need a wiring for dummies book. If you know how to use a set of wire strippers and crimpers you should be ok.
With me it took a while to get the hang of it. I understood the wiring diagrams in the instructions and I understood the wiring when I looked at it in the truck I just couldn't look at one and picture the other for a while. That slowly came together as I worked on it.
Shifty came over and helped me a little bit also and watching him work helped me a lot also so if you've got a buddy that can help, 2 minds are normally better than 1 (or 1/2 in my case)
-Homer Simpson
