60-63 tach dash???
I recently was a 67-72 guy but have just purchased a '62 C10 shortbox so I will be hanging out around here now. I have a question. The '62 I just bought has a factory tach in it. I was wondering how rare these are and what they're worth. Any help would be awesome. Look forward to hanging out around here.
-Greg My Chevy trucks, past and present: 1962 C10 SB Fleetside 1964 C10 LB Fleetside BBW 1966 C10 SB Fleetside 1966 C10 SB Fleetside BBW 1968 C10 SB Fleetside 1971 C10 LB Fleetside 1971 C10 SB Fleetside 1972 C10 SB Fleetside Cheyenne 1972 C10 SB Fleetside Cheyenne Super 1972 C10 LB Fleetside Cheyenne Super 1974 C20 Cheyenne 1979 K5 Blazer Cheyenne 1982 K10 SB Fleetside Custom Deluxe 1982 K10 SB Fleetside Scottsdale 1986 C10 SB Fleetside Silverado 2008 Silverado 1500 4x4 |
Re: 60-63 tach dash???
Welcome from New Mexico!
I know fewer came with a tach, not sure of the numbers or worth?
________________________ 62' ![]() 08' Chevrolet Silverado CrewCab 05'Toyota Tacoma Prerunner SR5 |
i know the reproduction ones run 170
last time i checked,noone made a repro tach for a 62.if it works i suspect you can get 200 up for it.im always seeing people wanting tachs for 60-63 trucks.
1964 c10 short step 1962 econoline van 1989 rs camaro 2006 yamaha vino 125 1975 goldwing |
oops my bab i didnt see the year
they are fairly rare..are you pulling it?...what are you using to replace, the factorys where part of the entire insert with the speedo etc...
wherever you go...there you are... |
I haven't decided what I'm going to do with it yet. Do they work better than the ones that came in the Impalas? Or are they notorious for not working like they were?
1962 C-10
My 62 has a gauge cluster that I pulled from a 63 that has a space for the tach, but no tach, I've thought about putting one...It also has gauges for the oil pressure and the temp instead dummy lights. Is this the one you have? I think it originally came out of a big truck of some sort because it has lights on it that say 'OVER SPEED' and 'TANDEM LOCK'. I know some of the catalogs offer these tachs new, but they say usually list them for 64-66's...Are they the same??
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
This one has guages (temp, oil pressure, temp, etc), a speedo and a tach in the upper right corner. I haven't seen the tandem lock or over speed. I do believe that the '64-'66 tachs are different.
About 2 wks ago there was a new Sun tach with the original box on Epay I can't remember the exact yr I think it was for 62 or 63 and it went for around $500. The 64 GMC i bought has a Sun Super tach with the adjustable needle in the dash, it fits right in the factory position, it looks like its been there a long time. I wonder did the factory use Sun Super tachs?
Mine has the Sun....I guess would call it the transmitter box (???) that mounts to the inside of the firewall under the dash.
