HELP WTf happened. (picture inside)
hello all. i need help figuring out what happened here. i started my truck today after my 454 swap and my steering box that hooks up to my ps pump busted open. i dont know what happened. im using the ps pump of the 1994 engine (my 454) that just bolted on
![]() Last edited by combustion; 03-15-2007 at 04:31 PM. |
![]() Join Date: Aug 2004
Re: HELP WTf happened. (picture inside)
Time for a new box. Looks like the new pump found the weak spot of the system. The later 73+ boxes have a quicker ratio anyway.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
its all about the +6 inches
not a quicker ratio, but a variable ratio
I've seen them get some water in them then freeze and burst like that.
SEMA Network- Protect our Hobby! 71 C30 in pieces, starting to come together. Click here for A Place For Tennessee Truck Enthusiest To Meet |
yeah same frame bolt pattern
'69 C10 SWB 350 edelbrock int/carb .420 .442 cam 700r4 70 lwb c10 work truck 250 I6 with two inch lift springs and a two inch bodylift and 33/12.5s |
LAIDOUT
How does that work exactly? When does it vary? I have been thinking about upgrading mine to something better.
GEARHEAD
You have to check the hydraulic hose ends. There are two styles that are not compatible. So if you go to new (I think its 78 or 79) it won't work with the older pump and vise versa. BUT, you can replace both the pump and box from newer with no problem, just have the hoses also.
HG, Oh hey, this is my 500th post.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
