Old 03-15-2007, 04:56 PM   #1
dave2953
Dave's not here, man
dave2953's Avatar
Fuel Pump Knock
My 68 has had a fuel pump noise ever since I swapped my 307 for an '86
305. I used the fuel pump and shaft from the 307 and it made knocking noises under load at slow speed. I got a new pump, but the noise remains. Any ideas??
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 03-15-2007, 07:41 PM   #2
Zeke
Active Member
Re: Fuel Pump Knock
Fuel pump cam lobe worn?
1969 C10 350 3spd
1995 GMC 3500 XC 350 dually
When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin
Zeke is offline   Reply With Quote
Old 03-15-2007, 07:54 PM   #3
dave2953
dave2953's Avatar
Re: Fuel Pump Knock
I don't think so. I haven't actually inspected the cam, but neither end of the pump shaft has irregular wear. Could that lobe be worn without the shaft showing any signs?
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
Old 03-15-2007, 10:00 PM   #4
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
Re: Fuel Pump Knock
Iwould think there would be some sign of wear. Are you 100% sure the pump is the source of the noise. A little trick is a long card board tube like from gift wrap kinda make an impromto mechanic stethescope. RJ22
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 03-16-2007, 05:20 AM   #5
dave2953
dave2953's Avatar
Re: Fuel Pump Knock
I use a piece of long heater hose as a "stethoscope". You can heaer the noise coming directly from the pump housing. I chased this noise everywhere before I could finally isolate it.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
Old 03-16-2007, 07:38 AM   #6
piecesparts
Parts and more parts
piecesparts's Avatar
Re: Fuel Pump Knock
I suggest you changeout the fuel pump. Those things are known to make a knocking noise when the rocker gets worn in the pivot point. It will sound like a rod knock, soon.
piecesparts is offline   Reply With Quote
Old 03-16-2007, 11:59 AM   #7
dave2953
dave2953's Avatar
Re: Fuel Pump Knock
I replaced it about 2 weeks ago, but no change. I thought trying an '86 pump, but it has the provision for the return. Can I still use it if I cap the return?
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
Old 03-16-2007, 12:30 PM   #8
piecesparts
Re: Fuel Pump Knock
YES, you can cap the return.
Old 03-16-2007, 12:36 PM   #9
dave2953
dave2953's Avatar
Re: Fuel Pump Knock
I may try that and see if my noise goes away. Thanks for help.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
Old 07-30-2007, 11:08 AM   #10
CST*TEN in Katy
Re: Fuel Pump Knock
Dave:
Did you ever solve your fuel pump knock? My broomstick tells me that is where my knock is located.
I found my all my other knocks- I learned that big cams and stock valve covers do not play well together.
1970 CST-10 owned it 26 years, finally back on the road after a 10 year rest.
1989 Suburban
1971 Sleekcraft 455Olds Berkeley
1992 SC400 pimp ricer
CST*TEN in Katy is offline   Reply With Quote
