Old 09-02-2002, 04:27 AM   #1
munkjeep
Question swapinf 4x4 front axles
can I swap a mid 70s GM dana 44 front axle in place of the closed knuckle, drum brake front axle I now have in my 69 GMC? Sorry if this had been covered a 100 times in past threads. if so is it a bolt in, or is there some major work ahead, Thanx, Munk
munkjeep is offline   Reply With Quote
Old 09-02-2002, 05:26 AM   #2
Pont
I need another Barley Pop
Pont's Avatar
Munk, should pretty much be a bolt in. I replaced mine with one out of an 80 Blazer. In 1980, the brake hose fittings went to metric so I had some changes to do there. Anything 79 and earlier shouldn't be a problem. It should bolt right in.
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
Old 09-02-2002, 12:53 PM   #3
chevytruck68
i have been wondering about this too i have a 79 4 wd short bed frame and drivetrain iwas thinking of swapping into my 3/4 ton 67 but my dad and i took measurements and there is like a 3 inch difference in the mounting pads on the front diff
68 chevy 2wd long step lowered 67 chevy 3/4 4x4 83 gmc suburban 350 od auto 3 in body lift
chevytruck68 is offline   Reply With Quote
Old 09-03-2002, 01:30 PM   #4
munkjeep
Is a blazer frame a different width than a truck ? It seem to be a blazer tie rod were too short to use on a chevy truck I had before. I guess I will have to go to the junk yard and do some more measuring.
