Old 03-15-2007, 06:52 PM   #1
shrtbx
305 died last night...time for a new engine
Well...just got the word that my 305 is officially dead. Its bitter sweet. I have a 350 with a new 383 crank in a box in the garage from an old project. Is it practical to drive a 383 stroker motor as an everyday driver on low octane gas. Just want some opinions. I think the rebuilding of the 305 is a waste of money although its practical. IM pulling my hair out lol ...a
shrtbx is offline   Reply With Quote
Old 03-15-2007, 06:54 PM   #2
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
Re: 305 died last night...time for a new engine
i like power so i never cared about mpg ill drive it no matter what it takes.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 03-15-2007, 07:06 PM   #3
shrtbx
would a 700 r4 handle the power?
Old 03-15-2007, 08:24 PM   #4
Srubydo1986
The Crazy Machanic
Should if u get a 1987 and up year transmission. One thing when installing a 700r4 (if it not whats already in ur truck) make shure it hooked up exactly the way it was when it came apart. Its very touchy about its shifting habits.
Just one peice of info dont do a neutral drop it, I completely blew my 1989 700r4 with B&M shift kit to dust along with a detriot lock rear.
newest additions
Old 03-15-2007, 08:44 PM   #5
Pyrotechnic
Pyrotechnic's Avatar
You can build the 383 up mildly. Infact, if you go with a mild performance street cam and maybe a set of Vortec heads (not sure what your budget is) you could probably build a more efficient engine and get decent mileage. Keep your compression ratio around 9:1 or so.
A 383 built the way I described above will put a hurtin' on any stock 700R4 on it's factory rebuild in no time. If you can find a reputable tranmission builder, they can rebuild one to take 300-400HP reliably if you have the funds to do that. A slightly higher stall torque converter will also help take advantage of the new power you have on tap.
Pyrotechnic is offline   Reply With Quote
Old 03-15-2007, 09:42 PM   #6
lurch115
lurch115's Avatar
*LOL* don't do a neutral drop in anything! 9 times out of 10 it does VERY bad things....
if i remember right they made a heavier 700r4....had a big "K" cast into the case....those are strong enough to handle about 500 horse...i know my 4X4 has a 700r4 with a shift kit in it and for the last 2 years i've owned it i've used it for tractor pulling and have never had a problem....shifts good and firm, and shifts when it should.....trust me..you wanna be tough on a tranny....try draggin' 30,000 lbs.....but thats just my opinion
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you."
'84 chevy half ton short box 2wd, 67,000 actual miles
'03 chevy 1500 HD crew cab 4x4 standard box, 6.0L
lurch115 is offline   Reply With Quote
Old 03-15-2007, 10:15 PM   #7
Srubydo1986
The Crazy Machanic
yea i got a 700r4 tranny just sitting in my garage with the big k on it was bad a*& when it wa in the truck but i rolled the truck and tranny only has about 1000 miles on it. (rolled cause i was to sick to drive, did any way)
newest additions
Old 03-15-2007, 11:01 PM   #8
alemanc
I agree. I'd go with the power.
alemanc is offline   Reply With Quote
Old 03-16-2007, 09:09 AM   #9
swb85
On a budget like Fred Sanford
swb85's Avatar
Go with the cubes!!! I'm building a ~450hp 383 to stick in my daily driver, gotta have a little fun on that daily commute.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 04-19-2007, 10:36 PM   #10
cuda
Where is this "K" cast into the case? I also am looking at stroking my TBI 350.
cuda is offline   Reply With Quote
Old 04-19-2007, 10:56 PM   #11
knightlife
Dark Heart Motorsports
knightlife's Avatar
I get 8 gas stations to a mile...Simon says go with the 383 so you can dominate all...buhaha!
How Deep Can YOU Bleed..?
1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter
2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD!
knightlife is offline   Reply With Quote
