Old 03-15-2007, 10:14 PM   #1
mothertrucker424
mothertrucker424's Avatar
rough country 4"
this is my last lift question i hope...i am buying the rough country 4" front leaf rear block lift with shocks
has anyone done this lift on there truck
was anything else needed??
p.s.-i also added the steering arm and dual stabilizer
this wont be my first lift but first one to a 72 chevy truck so its a new experience
and should i upgrade shocks?
mothertrucker424 is offline   Reply With Quote
Old 03-15-2007, 10:19 PM   #2
1969k10stepside
Re: rough country 4"
I have a 4" rough country lift on the 71 shortbed.It is actually closer to a 6" rear lift and 4" front lift.I bought the rear spring lift though.It was $600 for 4 springs and shocks and u bolts and all.
Here is a few pics with the lift:
1969k10stepside is offline   Reply With Quote
Old 03-15-2007, 11:35 PM   #3
62 short step
62 short step's Avatar
Attachment 250695
Attachment 250696
Love that truck, looking good!!
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 03-16-2007, 06:38 AM   #4
mothertrucker424
what did you think of the install was it simple? or they laided everything out nice and did you upgrade shocks? and what size tires and what kind of ground clearance
Old 03-16-2007, 07:04 AM   #5
Southedisto
River life......
Southedisto's Avatar
Solid axle trucks are pretty straight forward when it comes to installing a lift. There are several things that make it more difficult sometimes like crusty Ubolts, shock mounts, brake lines, steering arm nuts and the front spring mount bolts. Ground clearance does not come from the lift kit alone, you have to add bigger tires to increase ground clearance.
Southedisto is offline   Reply With Quote
Old 03-16-2007, 02:25 PM   #6
1969k10stepside
The tires are 35" Pro Comp Mt's.They are on 16x10 polished Eagle Alloy rims.I dont know the ground clearence right off hand.I can tell you the 35s are close to rubbing and will most likely off roading.I havent put the shocks on yet.With the 6" rear lift the supplied shocks arent fitting.I am waiting for the springs to settle a little more and if they dont then some different shocks will go on.The lift was pretty easy,the u bolts weren't stubborn but the bolts holding the rear springs on had to be torched off.I spent a few hours spread over a few days installing it.I changed all the bushings too,not just the ones for the spring eyes that come with the kit.
And thanks for the kind words 62 Short Step
Old 03-16-2007, 02:30 PM   #7
msgross
msgross's Avatar
brake lines might need extensions or replaced with longer lines.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 03-16-2007, 06:59 PM   #8
mothertrucker424
were is a good place for brake lines?
Old 03-16-2007, 07:14 PM   #9
Southedisto
River life......
Front brake lines at partsamerica/napa 88 c20. Napaonline will give you the length of the brake lines in their description. As for the rear, my rear didn't have hard lines, so I extended the mount for the rear hose and bent my lines to meet up with it at a higher location.
napa # for 1982 c20 UP 36954
napa # for 1988 c20 UP 38620 Length:25.125"
partsamerica for 88 H38620
Old 03-17-2007, 06:55 AM   #10
mothertrucker424
so i wanna get 1988 c 20 truck front hoses?
and rear just adjust mount
Old 03-17-2007, 09:19 AM   #11
Southedisto
River life......
Look around on the napa site, nearly all the brake hose have lengths posted. For my extension I used a piece of flat stock, two holes and wahlah! Of course I made new hard line with them going higher off of the axle. Here is a part number I found on napa.
***I have found two rear hoses to be metric, so just use some G2 when looking for one on later trucks***
88 c20 rear hose UP 38624 Length:17.75"
Old 03-17-2007, 06:25 PM   #12
vtblazer
vtblazer's Avatar
IMO, getting an all spring lift is the way to go. (unless cost is the main concern)
What you'll have are two differing spring rates front & rear.
Never mind, one old set and one new set of springs.
69K10step, with a 4" lift and 35's, there's no doubt you'll be rubbin' off road.
Mild wheeling, okay but anything more and you'll start messing up fenders.
vtblazer is offline   Reply With Quote
Old 03-17-2007, 08:08 PM   #13
1969k10stepside
Thats why after body work & paint it isnt going offroad
Whether I wheel it or not a different lift will most likely go on.I have a extra set of front 6" lift springs and since the back is already about 6 I think the 6" front springs might be going on in place of the 4 inch front springs.Dont know yet what I will do.....
Old 03-17-2007, 08:12 PM   #14
1969k10stepside
Oh and another thing.With rear blocks you will experience axle wrap that you dont get with rear springs.
Old 03-17-2007, 09:12 PM   #15
Eichorst69
I don't think anyone mentioned a raised steering arm???
And w/ a 4'' lift, 35's will rub the front of the front fenders. I had 35's w/ 4'' on my 69 and I had to trim the fenders. Original brake lines were long enough.
I have since added a 3'' body lift and 17/40 Ground Hawgs.
Rob
Eichorst69 is offline   Reply With Quote
Old 03-17-2007, 10:14 PM   #16
mothertrucker424
i did originally in first post but good call i ordered it today and will report my finding next weekend while i install it thanks
Old 03-20-2007, 06:21 PM   #17
mothertrucker424
i ordered my lift sat. with front leafs rear blocks and steering stabilizers and shocks and a steering arm i called today(tuesday) and they told me the leafs were on backorder and would be here sometime towards end of the week its a bummer i figured i'd be wheeling on sunday but i'll live
just figured if anyone cared about my trucks progress
well anyways i sanded the frame and painted it and fixed my front brakes and got calipers and hopefully hoses tommorow i'll post some recent pictures soon
PETE
