Old 03-16-2007, 12:58 PM   #1
bigblock69
Junior Member
Big blocks and long water pumps
Is it possible to use a long water pump on a big block? I want to run a serpentine pulley setup from March performance which requires the use of a long water pump. I spoke with technical support and was told to measure the distance from the front of the engine block to the radiator see if the dimensions are within limits; however, I do not have the core support or radiator installed yet. Will this setup work?
bigblock69 is offline   Reply With Quote
Old 03-16-2007, 03:29 PM   #2
kwmech
Re: Big blocks and long water pumps
The fan clutch will not fit with the long water pump, you may have to go to an electric
Old 03-16-2007, 05:46 PM   #3
clay68c10
clay68c10's Avatar
I agree, tried it with a stock 89 setup and the mech fan was not happening. From the fan mounting flange of the short pump to the rad core it's about 4.5in. I think the long pump is probably an inch longer at least.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 03-16-2007, 06:03 PM   #4
ratrod67
ratrod67's Avatar
I don't know about the serpentine set-up but I have a long pump on my 72.
ratrod67 is offline   Reply With Quote
