Old 03-16-2007, 10:44 PM   #1
cruisinlow67
Question decisions....
so i have been looking for a cab or a bed and havent had much luck here lately. so i have decided to order a few more things for my bag setup. the thing is i dont know what to order. heres a list of what i have for my 67.
2 re7 bags
50 ft of 1/2' airline
rear brackets
kp stepnotch
12 gallon tank (i went way overboard on that one)
switchbox
kp dual needle guage
2" blocks
i know i need fittings and valves.im saving those for last. im doing a front back setup. i need compressors but dont know what to get. for the front i have a 73-87 crossmember. what else should i get and what brands? also what type of fittings? compression or push to connect?
cruisinlow67 is offline   Reply With Quote
Old 03-16-2007, 11:36 PM   #2
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
Re: decisions....
here's a good thread for ya.
http://www.67-72chevytrucks.com/vboa...d.php?t=231525
assuming you have a coil truck, there's not need for brackets in the rear. just mount the bags in place of the old coils. also, go with 3/8 line and valves. 1/2 will dump way to fast. literally a 1 second slam on the ground.
i would also suggest not going cheap on the valves. get 8, not just 4. you don't want to tie your fronts together and you backs together. if you do, you will increase your body roll.
IvelDesigns is offline   Reply With Quote
Old 03-17-2007, 07:49 AM   #3
cruisinlow67
Re: decisions....
that helped a little but whats everyones opinion? who sells tubular trailing arms besides cpp?
