Old 03-16-2007, 11:34 PM   #1
Fl72Custom10
New Member
Fl72Custom10's Avatar
Picking up the cab
I picked up the new cab yesterday. It was a hard decision to replace my rust bucket because it has been with me a long long time, but it was the right one. (notice the aluminum foil patch on the old cab..)
I have another dash that I'm going to use to patch the radio cut out.
Question: It's a 71 cab for my 72 truck. Would you use a 71 mirror (mounted on ceiling) or a 72 mirror (mounted on windshield)? Are there any other differences between the 71 and 72 cab that I should look out for?
I should have washed it before I took pictures. That's just North Florida pollen on the roof.
Fl72Custom10 is offline   Reply With Quote
Old 03-17-2007, 12:25 AM   #2
wibilly
wibilly's Avatar
Re: Picking up the cab
71 cab should have a raised pad to mount rear view, other than that just the vent in driver door jamb i think
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 03-17-2007, 01:40 AM   #3
Rokcrln
Rokcrln's Avatar
My old 71 cab had both the raised rear view mount and the air psi release in the drivers jamb It was the only one I have seen like this. I now have a 72 cab for my 71 and I saved the raised rear view section to put into it.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 03-17-2007, 06:52 AM   #4
ChevyDude
My 71' has a raised mirror pad and an air release.
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 03-17-2007, 09:18 AM   #5
xmitsu10
xmitsu10's Avatar
Mine too
71 Cheyenne SWB
xmitsu10 is offline   Reply With Quote
Old 03-17-2007, 09:51 AM   #6
Hart_Rod
Hart_Rod's Avatar
Nice cab. Where'd ya get it? If you're ever over in PCola, give me a shout.
Hart_Rod is offline   Reply With Quote
Old 03-17-2007, 10:36 AM   #7
Fl72Custom10
New Member
Thanks. I got in on ebay. Drove to Alabama to pick it up - north of Birmingham. Well - - - I just noticed the vent in drivers door jamb is not there! Oh well. It does have a place for a dome light switch that my other cab did not have, as well as headliner and cargo light.
One more question: The old cab seems to have two larger holes above the fuse box mount, and the new cab seems to have one large hole and then a smaller one. Anybody know what the difference is?
