Old 03-17-2007, 12:51 AM   #1
opivyrocks
67 rear coil removal?
okay, sorry if this is a repeat but I looked in arcives and couldnt find a straight answer.
replacing rear coils in my 67 this weekend with a 3 inch drop coil. How would i go about this? I have spring compressers.. will I need them. I am trying to save my teeth and do this safely. thanks. a good link or directions would be great thanks
Jeff
opivyrocks is offline   Reply With Quote
Old 03-17-2007, 01:01 AM   #2
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
Re: 67 rear coil removal?
just jack the rear of the truck up, put it on jack stands about 12" behind the trailing arm X member, and let the rear end hang. But, leave the jack under the pumpkin with just enough pressure to hold it up... then remove the bolt on the bottom of the trailing arm.
should have no concerns there.
if the bolts are tough, you can alway cut the spring with the torch, then torch the bolts out.
IvelDesigns is offline   Reply With Quote
Old 03-17-2007, 01:01 AM   #3
cabinetguy
67 shorty
cabinetguy's Avatar
No Compressor Needed.put The Frame On Jack Stands And The Jack Under The Side Your Working On Undo The Shock First Then The Spring
67 SWB with enough parts to build two
cabinetguy is offline   Reply With Quote
Old 03-17-2007, 01:14 AM   #4
IvelDesigns
oh yeah, forgot the shock part
also make sure the brake line is long enough. you may need to disconnect it.
Old 03-17-2007, 02:10 AM   #5
cabinetguy
67 shorty
cabinetguy's Avatar
oh, and hopefully the bolt that holds the spring cup will just snap.there buggers.
Old 03-17-2007, 09:15 AM   #6
opivyrocks
Thanks guys that is pretty much what I pictured I had to do. I never even thought about the bolts being stuck in the trailing arms. Judging by the condition of the top bolts through the frame (threads rusted ..off look in the shape of hourglasses) I feel I am getting ready to do torch work. thanks again
Jeff
Old 03-17-2007, 10:59 AM   #7
cdowns
cdowns's Avatar
are you also installing an adjustable panhard bar so you can center the axel??
Old 03-17-2007, 11:25 PM   #8
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
not really needed w/ only a 3" drop.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 03-20-2007, 10:22 AM   #9
faribran
*** beware of the brake line and the wiring harness when u fire up the torch.
i just had to torch mine off...... i didnt have to touch the shocks..
faribran is offline   Reply With Quote
Old 03-20-2007, 01:24 PM   #10
Joe67
67 is sold
I agree, no compressor needed for the rear coils.
That job is no where as threatening as the fronts
ECE recommends an adustable panhard bar when you drop the rear four inches, three should be fine
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 03-21-2007, 02:21 PM   #11
XXL
Seņor Member
XXL's Avatar
Originally Posted by cabinetguy View Post
...Undo The Shock First...
I'd leave the shock attached on both ends. It's not in the way of the spring swap and it's only going to get smaller with the new spring installed.
XXL is offline   Reply With Quote
