Old 03-17-2007, 02:17 PM   #1
Jerry8168
Jerry8168's Avatar
where would the numbers on the rear end be located
Jerry8168 is offline   Reply With Quote
Old 03-17-2007, 11:38 PM   #2
Captainfab
60-66 Nut
Re: where would the numbers on the rear end be located
What are you trying to find out? There are usually some numbers stamped on the top of the axle tube (can't remember which side) but you have to have a way to decipher the code. If you're wanting to know what the gear ratio is, the best way is to remove the cover and read the tooth count on the ring gear and divide ie: 11 & 41 =3.73
