03-17-2007, 04:16 PM | #1 |
Adjusting Proportioning Valve
I am trying to trouble shoot a problem with my rear brakes. I am looking for the thread on how to adjust the proportioning vavle.
1972 Blazer body...need to get a thread started for the rest of the story |
03-17-2007, 05:11 PM | #2 |
Re: Adjusting Proportioning Valve
there is no adjustment on the combination valve
03-17-2007, 09:49 PM | #3 |
The Older Generation
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 03-18-2007 at 10:45 AM. Reason: Might help if I included the link???? |
03-18-2007, 04:42 AM | #4 |
There is a button under the black cap on one end of your prop valve. Use a clamp to depress & hold. Slowly push brake pedal to the floor or as close as you can get the pedal to the floor pushing firmly onthe pedal, and release. Remove clamp from prop. valve. It should be centered again.
GM sold a special tool for depressing the button. I just use a squeeze clamp.
71 Chevy CST Long Fleet 350/350/3.07 leaf rear. |
04-22-2007, 03:49 PM | #5 |
71Chev, Thank You. . . I was about to go spend 80 bucks for a replacement. I had checked my brakes top to bottom but couldn't get the light to clear. I looked in the Haynes manual -Pffffffff, what a waste! I tried your trick with a 6" C-Clamp. IT WORKED. Thank You, Thank You!
72 Chevy C-10 Custom LWB 383 Stroker - Edlebrock Air Gap intake and 670 CFM Holley Street Avenger carb. Hooker Comp Headers w/ X-Pipe and 2.25 duals TKO-500 & 3.08:1 rear I Love HEMI's, they're soft & chewy! |
