Finally a Bulldawg
Weatherstrip on now door won't close
I out new weatherstipping on my driver's side door and now I have to slam the door just to get it to close all the way. Is this normal? I got all of the old weatherstripping off before putting on the new. Will it settle or did I do something wrong?
Ah yes, the college life. School all morning, work all night, study when ya can. Uh... ![]() |
Progress = 0%
Yeah, it should settle over time. Mine did the same thing.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
Aren't door seals a pain in the butt? I installed new seals a month ago and only now are they settling in properly. You had to close the door with some authority shortly after installation. Just make sure everything is seating properly when the door is closed.
Also, it helps to cut a small slot near the joint to allow air to escape and enter. When I open my pass. door you can hear the seal sucking air in, lol (SSSSST).
1970 GMC 1500 Custom Original 350/TH350 Victoria, BC, Canada You can wish in one hand and crap in the other. See which one gets filled first. |
the windows are worst. i install the drivers side 6 months ago and the window is still hard to roll up
72 pickup:vortec heads,msd ignition,& m22 rock crusher |
"Trucks with Class"
![]() Join Date: Jul 2000
Some door seals are better than others---softer---and they do not close so hard.
I just did window regulators in my truck. One rolls up & down really easy...the other goes down easy, but up is a bear! I don't know what is going on...maybe sprung/damaged door. Remember, "If it is reproduction, you are going to have to work with it to make it fit"!!! |
dude we had the same problem with our 87 burb we just finished painting it put the weather stripping on and the door has to be slamed every time to close it My girl friend hates it .
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
1969 Custom 30 wrecker
After I installed mine I had the same problem but a few quick adjustments to the stricker plate and they were shutting great! As long as your doors are bolted on in the correct location, (lined up with body lines and the in/out of the door is correct, all that should be needed is a tweak or two at the stricker.
Don't put up with slamming your doors, you really don't have to.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
