Old 03-17-2007, 10:30 PM   #1
Broken_down?
Replacement of Stock Oil guage.
What is the size of the fitting that is in the intake? I cannot seem to get any size wrench to fit? Does it require a socket? If so, what size?
Don't get upset when she marks her territory in the driveway.
WHY DO THEY CALL THEM JUNKYARDS ANYWAY??? I LIKE TO THINK OF IT AS A TREASURE HUNTING MISSION
Broken_down? is offline   Reply With Quote
Old 03-17-2007, 10:39 PM   #2
woodrow59
OzarkHillbilly in Atlanta
Re: Replacement of Stock Oil guage.
A little confused (as I always am). Do you mean the line that runs to the oil gauge?
72 custom/10 LWB
68 Longhorn C20 Custom Camper (sold)
woodrow59 is offline   Reply With Quote
Old 03-17-2007, 10:48 PM   #3
Broken_down?
It is the fitting that goes into the intake behind the distributor. The oil guage line come out of the firewall and screws into the fitting behind the distributor.
Old 03-17-2007, 11:21 PM   #4
woodrow59
Just a guess, but it's probably worn out. You may have to put a pair of plyers or vice grips on it.
72 custom/10 LWB
Old 03-18-2007, 04:43 AM   #5
68caliRat
Need a bigger hammer..
That's odd. mine goes to a fitting on the drivers side block, under the 5-7 exhaust ports....Yes stock guage..
68caliRat is offline   Reply With Quote
Old 03-18-2007, 04:52 AM   #6
combustion
well beause the engines came out with different oil line socket locations. they allgo to the main gallery
If it`s 3.73 ratio you will spint the wheel 100 times to the driveshaft`s 373 times.Or,if you`re lazy,you could just spin the wheel once and the driveshaft will spin 3.73 times.Or, 3 and 3/4 turns.And if you`re real lazy,I can sell you a tab for whatever ratio you want.
Or,you could read all the suggestions and try those.It`s been well explained,I think,already.
combustion is offline   Reply With Quote
