Old 03-18-2007, 01:31 AM   #1
BK
BK Built
BK's Avatar
Yay Frame is HERE!!!
Just arrived this afternoon! yes, i still have some left. i have to brace and gusset my notch(i know i should have run it vertical, but its all i had access to), finish my hoop for my TA crossmember, finish weld everything, box the control arms, finish notching the upper control arm, and plumb and wire all my air ride, along with other things. anyway, just a few pics.
BK is offline   Reply With Quote
Old 03-18-2007, 03:55 AM   #2
smbrouss70
smbrouss70's Avatar
Re: Yay Frame is HERE!!!
Sweet, now get your @ss to work. That chopped burb body is gonna be killer on there. keep us updated on the pics!
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 03-19-2007, 12:47 PM   #3
Slmd92DIME
Slmd92DIME's Avatar
Looks good man now get to it
Slmd92DIME is offline   Reply With Quote
Old 03-19-2007, 01:09 PM   #4
1lowdiesel
1lowdiesel's Avatar
what size tubing did you use for the notch?
69 4wd V6 20k orig miles!!
05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored.
01 rcsb chevy 2wd 6bt cummins :devil:> build
xtremediesel.com
1lowdiesel is offline   Reply With Quote
Old 03-19-2007, 07:11 PM   #5
BK
BK Built
BK's Avatar
its 2x3x3/16. its too small, but i had already cut the rear off, and 2x4 was 3 weeks out. i just made it work. im thinking im going to re-notch the rear, but its going to be a pain to cut out the whole notch. but now i need the area to do it, i dont think the dealership is going to let me weld and cut on it here.
Old 03-19-2007, 10:08 PM   #6
BK
BK Built
BK's Avatar
well i decided that im going to redo the rear notch and framerails. i decided this because the notch i made horizontal instead of vertical. also, the rear framerails have a tow hitch welded to it, and some big akward mounts on it. this way, i can do the notch the right way, 2x4x3/16", i can make proper watts link mounts in the frame so they dont look tacky, and i can make the rails house my gas tank and both air tanks without looking funky. im going to try to draw up some plans on paintbrush. until then, here are some pics of the frame, and what im keeping.
4" dropped front framehorns and power steering linkage(gotta finish boxing the frame)
im redoing the whole rear notch and framerails. completely rebuilt and 60 over 327.
4" z, flipped notched ECE tranny crossmember(have to finish boxing it in. dad reinstalled it backwards, gotta flip it around, as well as get the tranny rebuilt due to fire damage)
(notice the welds i was doing with both flux core and gas, didnt realize i had flux core in it for a bit)
(again, have to finish boxing the auto tranny crossmember and flip it back around)
Old 03-19-2007, 11:42 PM   #7
1lowdiesel
1lowdiesel's Avatar
that sounds better but why not run 1/4 it's not that much more $.what are you gonna build the watts out of?
xtremediesel.com
Old 03-20-2007, 12:11 AM   #8
BK
BK Built
BK's Avatar
i suppose i could do it outta 1/4, but dont really need it i dont think. im not sure on the watts, i just have one mocked up from speedway motors that i modded. i think im going to make a 1-off diff cover that holds it, otherwise, ill make a bracket that houses the pivot point over the diff, that unbolts for diff access. then im going to mount the end pivots inside the frame, not on little tabs like they are. ill see if i can draw something up in paint. any other ideas, drawings, advice is very very welcome.
Old 03-20-2007, 12:36 AM   #9
Slmd92DIME
Slmd92DIME's Avatar
frame is giving me some good pointers man
Old 03-20-2007, 09:27 AM   #10
1lowdiesel
1lowdiesel's Avatar
what the hell caught on fire?
you could also do some 1 1/4 dom tubing w/ tabs at the end to mount to the rear and run a pete and jakes bushing in the center to some sort of custom center bracket.
xtremediesel.com
Old 03-20-2007, 10:24 AM   #11
BK
BK Built
BK's Avatar
www.cardomain.com/id/badpanl ... my 6" chopped shaved 65 panel burnt. thats what the frame is out from under. those are my plans for this suburban. check it out.
Old 09-01-2007, 05:14 AM   #12
L0WRIDE
L0WRIDE's Avatar
hey Brian how you getting on with the sub made any progress
49 CHEVROLET 1/2 TON, 52 CHEVROLET SEDAN
62 HARDTOP NOVA
65 CHEVROLET BB LWB FLEETSIDE
90 CHEVROLET EXTRA CAB
CHEVY ONLY - NZ Chapter
http://67-72chevytrucks.com/vboard/s...d.php?t=137984
L0WRIDE is offline   Reply With Quote
Old 09-01-2007, 05:23 AM   #13
satin64
satin64's Avatar
did you ever catch the #@&*% bastard that torched your truck?man i could really hurt the fool if i caught someone doing that kind of thing.
do you work on other peoples trucks?(hint hint)
satin64 is offline   Reply With Quote
Old 09-01-2007, 12:58 PM   #14
Dinos63
chevy only
Dinos63's Avatar
Man kid you did a killer job on the chop.Did this truck get burned up ? not many of us panel dudes left
Dinos63 is offline   Reply With Quote
Old 09-01-2007, 05:30 PM   #15
bagged81
Signals in the bumper.
bagged81's Avatar
That's a long ass frame, haha. Two words for this next one though....fender shirts.
Jeff C.
1981 Chevrolet Silverado - Under major construction...again. link
1962 Chevrolet Impala 4D Sedan moredoorclassics.com
1936 Ford Pickup - Frame-off in progress link
1979 Chevrolet Camper Special Flatbed link
bagged81 is offline   Reply With Quote
Old 09-01-2007, 07:30 PM   #16
satin64
satin64's Avatar
or fender skirts?
