Old 03-18-2007, 01:56 AM   #1
gpday06
gauges
i have a '68 c10 swb stepside, not like it matters, with the 6-gauge dash and i have the replacements from autometer, the 5" speedo, and tach, and the 2-5/8" oil press, ammeter, engine temp, and fuel level, what im wondering, is can i use these gauges, in my new truck??
gpday06 is offline   Reply With Quote
Old 03-19-2007, 12:02 PM   #2
hyarbour
Re: gauges
Sure. You can slip them in from the front or make a mounting panel so the gauges are behind the dash.
hyarbour is offline   Reply With Quote
Old 03-19-2007, 02:09 PM   #3
BowTieOgre
Re: gauges
Are you asking if you can take the Autometers out of the '68 and use them in a newer model truck? If so the answer is most likely no because you would need electric gauges rather than mechanical. If you are asking if you can install the Autometers in the '68 that is NEW to you then yes, as long as you have the mechanical gauges.
"New truck" thru me off.
1986 C10 - LWB, 305/700r4, posi, vortec heads
BowTieOgre is offline   Reply With Quote
Old 03-19-2007, 02:27 PM   #4
bobthecop
bobthecop's Avatar
Re: gauges
Is the bezel strong enough to hold them without any other support??
Happiness is towing your "new" truck home.
1972 C-10
1982 GMC (parts truck??)
1969 c10 parts truck
1969 C-10 ( my sons)
1992 Silverado 4X4 (now the boys truck)(now mine again)
2002 Tarus (my wife loves that car)
bobthecop is offline   Reply With Quote
Old 03-19-2007, 03:15 PM   #5
BowTieOgre
Re: gauges
I wouldnt count on it. I modeled my setup after THIS thread. You have to attach the gauges to the metal insert in your old cluster and secure it to the bezel with the modified rear piece and some longer screws.
Old 03-19-2007, 03:28 PM   #6
bobthecop
bobthecop's Avatar
Re: gauges
1972 C-10
