Old 03-18-2007, 04:32 PM   #1
Broken_down?
block casting numbers?
01 0
02 0
146
Found on the drivers side next to the oil filter on the side of the block. I was looking for some numbers to confirm this 350 came out of a 71 like I was told.
thx
Don't get upset when she marks her territory in the driveway.
WHY DO THEY CALL THEM JUNKYARDS ANYWAY??? I LIKE TO THINK OF IT AS A TREASURE HUNTING MISSION
Broken_down? is offline   Reply With Quote
Old 03-18-2007, 05:01 PM   #2
KFreddy
Active Member
KFreddy's Avatar
Re: block casting numbers?
Funny # it should be a string of #s 7 or 8 digits long. Something like 3858618. Infact the # should start with a 3, a # that starts with a 1 for with a few exceptions is an 1980 and newer motor. Remember that somtimes 6 look like 8s and 8 look like 3s, sometimes the casting of the #s is a bit rough...
Hope this helps,
-Fred
KFreddy is offline   Reply With Quote
Old 03-18-2007, 05:08 PM   #3
Broken_down?
Am I looking in the right place?
Old 03-18-2007, 05:13 PM   #4
CrashEd
72 chevy
CrashEd's Avatar
SBC on the passenger side bellhouseing flange looking from the top of the motor.
CrashEd is offline   Reply With Quote
Old 03-18-2007, 05:15 PM   #5
blukangoo
Neighborhood Pickle Slinger
blukangoo's Avatar
Should be right here just like CrashEd said.
My C10 Diary
Our cars:
1966 Chevrolet Chevelle 396 - TH350
1968 Chevrolet C10/CST 327 TH400/375
1969 Corvette Stingray 350 - Muncie Manual Trans
1969 Chevrolet ElCamino 350 - TH400
1970 Cutlass Supreme Convertible - 350 Rocket - TH350
1973 Camaro LT - New Engine Done - TH350
1973 Corvette Convertible 454 - TH400
blukangoo is offline   Reply With Quote
Old 03-18-2007, 07:44 PM   #6
Broken_down?
Well the number was 3970010:
This website said it is:
150 3970010 350 CID 300,350,370 HP 1970 Normal 4 Bolt Main Corvette and late 1969
This is pretty good right?
Old 03-18-2007, 08:02 PM   #7
Big Block
Big Block
Big Block's Avatar
If it is out of a truck, should be 4 bolt main block. 3970010 is a common # used for 350 block.
Big Block is offline   Reply With Quote
Old 03-18-2007, 09:49 PM   #8
KFreddy
Active Member
KFreddy's Avatar
I came up with three posibilities for the casting #, I would assume that it is the second one, however it can be crossrefrenced by getting the casting #'s off of the heads. On a long shot you might just have gold on your hands
Casting #...ci.......year....bolt......type/usage
3970010....302.....69........4........Z-28 Camaro
3970010....327.....69........2........Trucks and industrial
3970010....350.....69-80....2 or 4..Dealer Replacement
Old 03-18-2007, 10:18 PM   #9
Broken_down?
Where are the head cast numbers? On the front or side?
Old 03-18-2007, 10:24 PM   #10
TheSasquach
Under the Valvecover between the rockers. David
TheSasquach is offline   Reply With Quote
