Old 03-19-2007, 12:05 AM   #1
bigo181979
Junior Member
bigo181979's Avatar
LT-1 engine towers, what to use???
Ok I just got my LT-1 in and I have a cople questions. I am a bit confused, I want to use the further back position to mount the motor so I have more clearance for the radiator fans and what not.
So what do I use the V-8 towers in the rear location?
Or do I use the I-6 towers in the rear location?
Then what motor mounts do I use?
bigo181979 is offline   Reply With Quote
Old 03-19-2007, 07:04 AM   #2
Rokcrln
Rokcrln's Avatar
Re: LT-1 engine towers, what to use???
V8 mounts in the rear holes and I think I used the caged style older chevy camero mounts
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 03-19-2007, 05:04 PM   #3
Americanrider
http://www.classicperform.com/tech_a...ngine-Swap.htm
This may help
Americanrider is offline   Reply With Quote
Old 03-19-2007, 06:07 PM   #4
bigo181979
Junior Member
bigo181979's Avatar
Originally Posted by Americanrider View Post
Yeah I have seen that, but thats for gen III LS motors, I have a gen II LT-1.
Thanks though.
Old 03-19-2007, 11:05 PM   #5
bigo181979
Junior Member
bigo181979's Avatar
ttt
Old 03-19-2007, 11:05 PM   #6
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
You can use the 6 cylinder mounts in the 6 cyl position
low'n slow is offline   Reply With Quote
Old 03-20-2007, 05:50 AM   #7
Wootdog
Wootdog's Avatar
Go to hotrodlane.com. IT is Street and Performance. They can answer your question. That is who I used. I don't remember exactly what I did. Lambert there should have your answer. Kerry
1967 C10
Got it back after three years
Boy I sure missed Peppy
1969 Chevelle
1990 IROC Z Convertible
2002 Silverado LT
Wootdog is offline   Reply With Quote
Old 03-20-2007, 06:36 AM   #8
brak
brak's Avatar
just pick up some I6 towers which mount in the rear position.
if you can wait a couple weeks, i have a pair you can have, otherwise check the classified section, they're always popping up pretty cheap.
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 03-20-2007, 08:46 AM   #9
bigo181979
Junior Member
bigo181979's Avatar
Thanks I have some one who has a set for me locally I just wanted to make sure I needed the I-6 towers.
Now what do I use for the motor mounts on those towers?
