Old 03-19-2007, 01:26 AM   #1
bowtieride
Rust in my gas tank?
The other day i was wondering if the gas gauge worked so i took a flash light and shined it down in the tank. There seems to be alot of rust down in the tank and some in the tube. Is this common for a 1970? It really seems like alot down in the bottom. I had a 71 some years back and i dont remember it having any rust in the tank.
bowtieride is offline   Reply With Quote
Old 03-19-2007, 04:48 AM   #2
JimKshortstep4x4
Re: Rust in my gas tank?
If the inside of the tank is rusting and the rust particles are moving through the gas line sooner or later other problems will develop. The fuel filter will plug up and fine rust will get into the carb causing the engine to run poorly or stall.
If the rusting continues a hole may develop in the tank.
It is best to either replace the tank or have the tank boiled out and coated inside. Good used tanks are available as well as new ones.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 03-19-2007, 04:59 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
a good shop won't boil it out, they'll steam clean it instead... otherwisw, I agree with jim.
