03-19-2007, 11:12 AM | #1 |
Wanted: 1974 pics and info.
Hi. I have an opportunity to look at a scarcely used 1974 with a 454. Could someone post a picture of a 1974 (my current '69 is the latest model I've ever had) and tell me if there were any particularly options to look for,or any weaknesses to check out. It sounds like a very pristine truck. I'll post some pictures when I get to look this week.Much thanks-Brian
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
03-19-2007, 02:45 PM | #2 |
www.73-87chevytrucks.com
Re: Wanted: 1974 pics and info.
Check this page:
http://brochures.slosh.com/index.shtml?1974 Options to look for, buckets, tilt, BBC, A/C, CB radio, Cheyenne Super trim (top of the line)
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
03-19-2007, 03:27 PM | #3 |
Thanks,that's exactly what I was looking for. BTW, Is that 230 HP rating for the 454 understated or is it realistic? That is only 30 more Net HP than my current '69 350 4V.
03-19-2007, 03:53 PM | #4 |
K5Camper
THat rating should be NET horsepower as they changed from the "gross" rating method around 1972. Gross is with no accessiories, no full exhaust, just the engine with nothing on it. Net is the engine with all accessories installed (alternator, p/s, ect), full exhaust and emissios junk.
So yes, number to number your 69 350 is only 30 ponies shy of the 74 454, but your 69 350 rating is "gross" and the 454's was "net". Meaning, if you rated your 69 350 with the "net" method, it would have a lower number. Keep in mind, the 454 in 74 had lower compression and other steps taken to make it more emissions friendly, so it's not a powerhouse like the LS6 450 hp 454 from 4 years earlier. It probably has the small heads too. It's a good foundation, but wasn't built for all out power like the LS6 was.
Rob Z. 1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP 1991 K5 8.1L/NV4500/241/D44/14b FWC Camper |
03-23-2007, 12:17 PM | #5 |
Thanks. Does this 1974 454ci have the potential to be practical if I install headers,remove any smog crap that affects performance,and make other tweaks,or is it doomed to be a gas-hog with marginal performance.I've never had a big-block and gas is quickly approaching $3.50/gal here.-thx,Brian
03-23-2007, 04:15 PM | #6 |
It could be an efficient engine with the right compression ratio, a mild street cam, better heads, a dual plane aluminum intake, and long tube headers, and a properly tuned carburetor. I wouldn't bolt these items onto that old of an engine though. I would go ahead and pull the engine, have it completely rebuilt and balanced and then install the new performance pieces.
The biggest problem with these engines is the extremely low compression ratio, so a head change at the least will be required. |
03-24-2007, 12:55 AM | #7 |
Thanks Pyro,really appreciated.I will be looking at a very low-mileage '74 that's been in storage.
>>I know that here in California they also had the timing advance come in real late to reduce smog.I would totally recurve an HEI and put adjustible vac.adv unit. >Maybe if I just mill the heads and switch cams,add headers,tune the carb etc. It'll be OK. I could live with 10MPG overall. Thx-Brian
03-25-2007, 12:58 AM | #8 |
I think those trucks had the air pump set up and a carbon canister from the factory not really sure about any other emissions. The only problem areas that I can think of is just general body rust. They don't seem to get quite as bad though as the older ones. A California truck should be pretty good. I had a 74 C10 Cheyenne Super from Dallas before and it was solid as a rock.
Looking forward to your pictures! I really like the 73/74 models. |
03-25-2007, 12:40 PM | #9 |
"these engines is the extremely low compression ratio"
This is a good thing if you have a small supercharger available to bolt on. The small street type blowers were initially meant to bolt onto low compression smog motors and give anywhere from 50 to 75, sometimes even more horsepower on a stock motor running low boost. Still would go through the motor as was said earlier just for peace of mind on something thats over 30 years old. |
03-25-2007, 06:40 PM | #10 | |
04-03-2007, 11:58 AM | #11 |
Any pictures yet?
04-03-2007, 07:51 PM | #12 | |
'lox'
04-03-2007, 09:16 PM | #13 |
Thanks for the info in the above. The guy seems to really be dragging his heals on showing it to me and I'm slow-playing it to not look anxious.But the fact is that every time I go past the ARCO, gas is even higher,so in fact I'm actually not too anxious anymore. The report I got was " old geezer in rich neighborhood,used it once on trip to Grand Canyon,pristine orig.cond." Will post pics when I have them. Brian
