Old 09-02-2002, 09:04 PM   #1
Jwill41
Jwill41's Avatar
found this 72 today
I ran across this truck today. The guy is asking 2000.00 for it and says it runs good but the shifter is broken off. What do yall think and is the shifter easy to fix? Truck is really pretty rough.
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
Old 09-02-2002, 09:05 PM   #2
Jwill41
Jwill41's Avatar
2
Old 09-02-2002, 09:06 PM   #3
Jwill41
Jwill41's Avatar
3
Old 09-02-2002, 09:07 PM   #4
Jwill41
Jwill41's Avatar
4
Old 09-02-2002, 09:08 PM   #5
Jwill41
Jwill41's Avatar
5
Old 09-02-2002, 09:09 PM   #6
Jwill41
Jwill41's Avatar
6
Old 09-02-2002, 09:10 PM   #7
Jwill41
Jwill41's Avatar
7
Old 09-02-2002, 09:11 PM   #8
Jwill41
Jwill41's Avatar
8
Old 09-02-2002, 09:21 PM   #9
Mike C
Mike C's Avatar
Pretty clean looking 4x4 for that price. I'd be concerned about the shifter, though. How the He!! do you do that?! Hopefully no internal trans damage, but...
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 09-02-2002, 11:13 PM   #10
breeh
Recovering 67-72 Addict
breeh's Avatar
Price doesn't seem to far off of the mark to me. I believe that those shifter arms are fairly simple to replace. Push down on the little dome and turn counterclockwise. It should then come out.
Oops, I went back and looked again. You already did that
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 09-04-2002, 05:18 PM   #11
Yukon Jack
Post Whore
Yukon Jack's Avatar
Price doesn't sound too bad. Looks like pretty tight clearance for the front tires near the rear of the fender. I have no idea on the shifter, hopefully that piece isn't jammed in there. Wonder how it happened.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 09-04-2002, 11:48 PM   #12
neonlarry
neonlarry's Avatar
I would pay 2k for it (if I had the money lol)
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 09-05-2002, 08:55 AM   #13
Jwill41
Jwill41's Avatar
Clearance is tight on the front. Both fenders look like they have been mangled by the tires. The front bottom lip has been cut away on both sides also. Maybe that was because of rust problems.
Old 09-05-2002, 04:13 PM   #14
Chevy409
Giddy up giddy up...
Chevy409's Avatar
Thumbs up
Gimme the tires! What are those, 35's? Not a bad truck for 2 grand but talk him down to $1500 and you'd have the deal of the day.
72 with 69 grille and custom 73-87 stepside. BIG BLOCK 409, SM465, NP205, 3/4 axles slung under a 5" lift, 3"bodylift, 112" frame, and 35inch Pro Comp X-terrains... "BUILT NOT BOUGHT" Here's the site...
Chevy409 is offline   Reply With Quote
Old 09-06-2002, 04:33 PM   #15
Crank
Crank's Avatar
You didn't say rough did you!?!?! That truck is purdy. Hell with the tires hittin the fenders. Let it go for now, i think it looks tuff. Well from what i can see, it has a small block and is 3/4 ton. Any more info??? Oh yeah, the shifter should come out. if not at first, you might have to use some sort of redneck inginuity.
Brandon
Crank is offline   Reply With Quote
Old 09-06-2002, 10:16 PM   #16
Blue_71
Bloo
Blue_71's Avatar
i dont really knwo HOW it happens but i think that has happened to my 4x4 too.. the shifter on it has been broke off and another welded onto the ball that sits in the top of the tranny.. it doesnt have the down-over-down shifter of a 67-72, it has a over-down shifter like a 88-?
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 09-07-2002, 12:17 AM   #17
DaHateTank
not sure about 2K...but then again, you don't get much 4WD, for that price.
If the engine IS sound, and everything works, w/o extensive cobbling, its maybe reasonable. The rockers are gone. Up here that means the floors are shot, too. May not be the case, in Texas, tho.
Id pull the shifter hump, and take the top of the tranny off. SHould be able to get the shifter stub out that way, and check to see if the inside of the tranny is fragged, as well...
Im not high on that rear axle, either (strong, but not too common, anymore -- read: parts availability), but then a 14 bolt FF is a pretty easy swap, IMO.
Be nice if the AC was still there...
just some things I notice/ my $0.02
-M
DaHateTank is offline   Reply With Quote
Old 09-16-2002, 02:15 AM   #18
chevypete396
chevypete396's Avatar
I have the same 4-speed in mine and the same thing happened to my stick. They are sort of weak around the base after 30 years of hard shifting.
A few tips:
Pop those two spring pins out that hold the pivot ball. It makes it alot easyer.
Make sure the tranny is in neutural (use the e-brake) when you pull the old stick out.
Its a little tricky putting it in neutral with no stick. Have someone rock the truck and use a lot of pressure and a really big screwdriver
I ordered a new stick for 45 dollars from some place in Utah and had to bend it myself.
But UPS trucks have the same tranny so it shouldn't be that hard to find a replacement stick you don't have to bend. Because it was very hard to bend without tools. Good thing I eat my wheaties...Pete
1968 Chevy - 3/4 Ton - 4X4 - Longbed - 383ci - TH350 - NP205
Building the motor, painting the engine bay, rewireing everything...
(775)-527-1199 / ryanspeterson@msn.com
chevypete396 is offline   Reply With Quote
