Old 09-02-2002, 09:10 PM   #1
mikep
Used to have a truck
mikep's Avatar
Shifter renew question
I just pulled the shifter handle out. I'd have to say that once I figured out that only the outer collar has to turn it was a snap to take out. Anyway there is a roll pin at the end of the shaft. The hole that the roll pin passes through looks sloppy ( the outer collar ). Should that be a tight fit? Shoud I ream it out for a larger OD pin. will that tighten my shifter play up?
No truck :-(
mikep is offline   Reply With Quote
Old 09-02-2002, 09:14 PM   #2
CE20934
CE20934's Avatar
Location: Help! I'm in an office park with its own network of freeways!
That fit should be tight. At least mine is.
Go ahead and put a larger roll pin in. I don't know how much play--if any--it'll take out, but it's worth a shot.
'67 C20--427 tall deck/SM420, 4.10 HO52 (Michigan has not been kind to the Old Man)
'95 Caprice--355 LT1/T56/3.42 8.5" 10-bolt (daily driver, almost 300k on the chassis)
'07 Outback--wife's car. 125k & counting. No head gasket or transmission issues yet. *fingers crossed*
CE20934 is offline   Reply With Quote
