Old 03-19-2007, 08:03 PM   #1
albertarose
albertarose's Avatar
5 bolt vrs. 6 bolt homework DONE !
I have a Short box step big block truck (69) it has the origional power drum 6 bolt set up ..I thought about going 6 bolt disc but after looking for wheels with normal offset I realized why people like 5 bolt better ..you have a limitless selection of wheel possibilitys ! during this wheel hunt I found a guy a few hours away from with a 72 parts truck that is not too picked over (yet)..just the engine and front fenders ..his price seems fair and with a little luck I will be able to sell whats left over.. ..I havnt seen it yet but I am going there prepared to drag it home next wk end. Although my shorty is a real CST 396 truck ..its not numbers matching anyway and I think its a fair trade to be running 5 bolt disc ..any tips or advice on my plan ? it should be fairly straight forward.. KEEP ON TRUCKIN!
albertarose is offline   Reply With Quote
Old 03-19-2007, 08:04 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: 5 bolt vrs. 6 bolt homework DONE !
rotors are dirt cheap and avalible anywhere in the nation when you run 5 lug too.
Old 03-19-2007, 08:18 PM   #3
GREASEMONKEY72
GREASEMONKEY72's Avatar
5 bolt is alot easier to find wheels for and incase you dont know yet the bolt pattern is 5 on 5 for the 5lug
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 03-20-2007, 10:05 PM   #4
BarryB
BarryB's Avatar
the only thing I see that might be a con, factor. weren't the 72's leaf spring rearends?? The axle swap won't work either because there to wide. You might have to find a 71 rearend which I believe are coilsprung. Or have your old ones drilled for the 5 on 5 lug pattern.
BarryB is offline   Reply With Quote
Old 03-20-2007, 11:24 PM   #5
albertarose
thanks man never concidered that ! ...will scope it out when I go to see the truck..
Old 03-20-2007, 11:27 PM   #6
GREASEMONKEY72
72s are coil rears i know because mine is, leafspring i believe was an option so coilspring is standard
-steven
Alte Seele S.S.
Old 03-20-2007, 11:33 PM   #7
1969k10stepside
Yes the 5 lug rears are different than the 67-70s with 6 lug.No,most were coil springs on Chevys and most GMCs were leaf spring rear ends.Some chevys had leafs and some GMCs had coils.72s didnt just have leafs,they had coil spring rear ends also,it could be either.73 is when they all went leaf in the back
1969k10stepside is offline   Reply With Quote
Old 03-20-2007, 11:36 PM   #8
GREASEMONKEY72
thats what i was thinking of, chevy=coil, gmc=leaf with a few exeptions
-steven
Alte Seele S.S.
Old 03-20-2007, 11:43 PM   #9
CG
BlahBlahBlah
Some of the board vendors sell the correct size five lug axels to swap into your six lug housing
Old 03-20-2007, 11:51 PM   #10
albertarose
ok that makes sense ..didnt even ask him if its a chev or gmc thought they must be same Im learning here! thanks!! its not going to be a big prob if thats the case.Just have to track down some axles then...
Old 03-20-2007, 11:53 PM   #11
albertarose
thanks CG !!thats always an option too ...cute kid picture by the way!
Old 03-20-2007, 11:58 PM   #12
albertarose
yeah I might get lucky and find coils under my parts truck..dont remember finding any leaf set ups on 67 to 72 trucks gmc or chev here in canada at the bone yards but Im not going to be suprised now if I do !
Old 03-21-2007, 12:00 AM   #13
albertarose
ok now Im confused ..is yours a gmc greasemonkey ?
Old 03-21-2007, 09:16 AM   #14
gmc1969custom
My 69 GMC Custom must be an exception since It's got rear coil springs.
1969 Custom w/Turquoise Interior. 75k miles, 350 V8, THM400 (Almost) All Original
gmc1969custom is offline   Reply With Quote
Old 03-21-2007, 04:50 PM   #15
grayw0lf
Are the 6 lug wheels really that hard to find? I was really wanting to go 6-lug w/ a setup from a later model truck w/ the 1.25" rotors.
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 03-21-2007, 06:16 PM   #16
turner15
my 71 GMC is coils and 5 lug, it was made in Oshawa Ontario
turner15 is offline   Reply With Quote
Old 03-21-2007, 06:43 PM   #17
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
6 lug wheels are everywhere. Just not as everywhere as 5 lug wheels.
Old 03-21-2007, 07:04 PM   #18
msgross
msgross's Avatar
you can do the economical impala/camaro rear disc conversion for 5 lug too. If you run into a leaf rear end then I can send you the trailing arms pad mounts (or whatever the part welded onto the axle is for the axle to convert, you pay shipping and they are yours...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 03-21-2007, 07:06 PM   #19
msgross
msgross's Avatar
Is the width of a coil vs leaf axle different?
The Garage:
