Old 03-19-2007, 08:49 PM   #1
BowTieOgre
Brake Line Sizes???
Even though it isnt too expensive to just buy the pre-bent brake line kits I think I would really like to bend my own just to have the experience. Im wondering what size tubing I should use. I will have a 4 wheel disc setup using rear rotors from a Caprice. I have a CPP booster/mc/prop valve for a disc/disc application.
It looks like the old drum brake line going across the rearend was about 3/16" and the line running to the front looked a little bigger...maybe 1/4"?
Any suggestions on line sizes, fittings or tips in general would be greatly appreciated.
1986 C10 - LWB, 305/700r4, posi, vortec heads
BowTieOgre is offline   Reply With Quote
Old 03-19-2007, 10:10 PM   #2
short69
short69's Avatar
Re: Brake Line Sizes???
maybe you could just check what size the female fittings are on the prop valve and go with that...I'm guessing that the front and rear lines would be the same size.
69 shorty w/ 67 front clip
short69 is offline   Reply With Quote
Old 03-19-2007, 11:28 PM   #3
BowTieOgre
I may end up doing that if I dont get any more opinions.
Old 03-20-2007, 08:29 AM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
1/4 and 3/16 are the sizes. Be forewarned though, you'll need to salvage the fittings off of the original lines for some of the connections. The generic straight lines from the parts store are the right diameter, but the fittings sometimes are wrong to screw into the prop valve. The GM fittings are thicker to make the 3/16 line screw into a larger hole.
Just clean em up and put them on the new line before you flare and bend it.
Old 03-20-2007, 08:44 AM   #5
BowTieOgre
Thanks for the help TXF. I will be sure to post a pic when I get it plumbed.
