67/72 ft. cross member f/s
![]() it looks to be in good shape should fit 67/72 and maybe some other years $50.00 no shipping. |
Re: 67/72 ft. cross member f/s
Hmm, I'm converting from divorced to married t-case. How can I be sure this would work?
'70gmc 3/4ton 4X4, re-arch and 2" add-a-leaf lift. '77 400sbc, '82 axles, d60front, 14bolt rear. Probably some 285/75/16 Toyo m/t's on my stock rims coming up. |
this one is a 2wd i dont think its the same as a 4wd.
Tis be true,that is a crossmember the a arms (or what ever you call them) and the motor mounts bolt to,For a 2wd.
Martin,you need a transfer case crossmember Last edited by 1969k10stepside; 03-21-2007 at 10:53 AM. |
