Just converted to a "van" tilt column. Does anyone know a way to set up a enutral safety switch on a van column in our trucks?
Huck, I used my old neutral safety switch. Just made the hole at the approximate location on the van column. Cut it out with a dremmel or some kinna cut off tool. Welded a little tang on the inner column made from a small piece of scrap metal. Set the switch on it and checked it with an ohm meter to determine where to put the mounting holes. I also mounted the switch up on the column about 4" or so from the old column so I could drop the column and get the steering wheel closer to the dash.
69 C-10 CST Short Fleet, Factory Air, BB427-400 Auto-2400 stall-tilt-cruise-Tach & Vac Gagues, 4/6 drop, power one piece side windows, Eaton posi. |
Used a van switch on one here. Just located the switch lower. Used the regular column for distance measurements. Did not have a welder for the tab as suggested in abovepost.
The same type slot was cut out of the tube for the switch to fit. Used a small cutting wheel. Drilled a hole for the vans switch tab to fit into the inner tube. It works but of note is also the wiring plug on a van column switch is a little different also... made an adapter, didnt want to cut wiring. Hmm is it really 4:30 in the morning. Truckaholic Rod
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
