03-20-2007, 12:27 PM | #1 |
I need a measurement
I'm installing new angle strips on my bedsides. Can someone who has a stepside please measure from the top of angle strip to the top rail of the bed so I know where to mount them? Thanks in advance for your help.
'70 GMC SWB step-side- 454, 4 speed, air bags (in progress) '09 CTS-V M6 '03 Sierra SWB Z71 '82 Yamaha Seca XJ650R Turbo! '04 Yamaha FZ6 |
03-20-2007, 07:47 PM | #2 |
Re: I need a measurement
It is 16 1/2" from the top rail to the top edge of the angle.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
03-20-2007, 09:34 PM | #3 |
Thank you. Now I can go put them on. I really appreciate your help. -russ
03-21-2007, 01:19 PM | #4 |
Truck Parts Mfg.
Russell:
We like to make the measurement to the bottom of the angle strip in case the vertical leg is not always the same. To be safe, install the rear sill and front panel to the bed side then put a 3/4 piece of wood along the bed side over the front panel flange and the rear sill. Make your measurement down to the top of the wood and that is the same as the measurement to the bottom of the angle. By making the measurements directly on your bed side, you know the wood will fit right, not too tight and not too loose. Angle installation instructions are on the Mar-K website http://www.mar-k.com/54-72anglestrips.pdf Mar-Ktech
GET MAR-K Quality! Restoration and Custom Pickup Parts for Chevy, GMC, Ford, Dodge and Custom Trucks |
03-23-2007, 12:02 AM | #5 |
Thank you very much. That was very informative. This board rules!
