Old 03-20-2007, 02:21 PM   #1
Rascal_one2001
Rascal_one2001's Avatar
Question wireing problem?
I just put in a new incab harness in my 70 since the old one had some problems with the cluster wires and wipers and lights wires were cut but the ignition worked awsomely and now with my new harness in I turn the key on and the gauges and wipers and stuff works put wont turn over my truck. I tryed my engine wires first and then I thought mabe it just needed the other engine harness but same thing. What do yall think it is.
1985 1500 454, 4l80e, 12 bolt, 5/6 drop, 20s
Rascal_one2001 is offline   Reply With Quote
Old 03-20-2007, 02:47 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: wireing problem?
Is it in park? Is the neutral safety switch plugged in?
Old 03-20-2007, 03:20 PM   #3
cdowns
cdowns's Avatar
you should have a heavy(12gouge) purple wire going from your ignition switch to the neutral safety switch and from the safety switch to the starter
Old 03-20-2007, 03:21 PM   #4
67ChevyRedneck
67ChevyRedneck's Avatar
Does it do anything when you turn the key (motor-wise)? Does it click?
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 03-20-2007, 10:47 PM   #5
Rascal_one2001
I think it is the neutral safety switch my old harness looks to have some meatal jammed in the connector ) i guess to bypass it. Thanks for the help guys I'll hook some sort or switch up that mounts at the base of my automatic floor shifter so I still have that safty.
