Old 03-20-2007, 02:22 PM   #1
BK
BK Built
BK's Avatar
frame welding settings?
quick question, what settings are you guys running on your welders, heat, speed, size wire, for welding up frames, 1/4, 3/16, and 3/8? just curious.
BK is offline   Reply With Quote
Old 03-20-2007, 05:31 PM   #2
bobthecop
bobthecop's Avatar
Re: frame welding settings?
ttt
Happiness is towing your "new" truck home.
1972 C-10
1982 GMC (parts truck??)
1969 c10 parts truck
1969 C-10 ( my sons)
1992 Silverado 4X4 (now the boys truck)(now mine again)
2002 Tarus (my wife loves that car)
bobthecop is offline   Reply With Quote
Old 03-20-2007, 07:10 PM   #3
thekid54
That's a pretty vague question. There are a lot of factors involved like wire size, type of shielding gas, type of machine, etc. I adjust my settings to get good penatration and a good looking weld. That could vary depending on where and what I'm welding (vertical, overhead, thick-to-thin,etc.) I have a Millermatic 175, CO2/Argon mix gas, and .030 wire. On frame stuff I was usually running 7-9V and 70-90 wire speed. Hope that helps.
thekid54 is offline   Reply With Quote
Old 03-20-2007, 08:58 PM   #4
BK
BK Built
BK's Avatar
yeah, thats what i did mostly on my frame, and all my sheetmetal fab, i had lots of test welds first. i just ordered and will be arriving soon a licoln 180t mig and plan to use gas. Im going to be re-back-halfing my frame, and will be welding 3/16 metal. i will bevel all edges, and do continuous welds. i was just curious. im sure when i get it, ill get back into it really fast, its just been a while.
Old 03-21-2007, 12:36 PM   #5
Slammed67
Progress = 0%
Slammed67's Avatar
My Miller 210 has a settings chart under the cover that gets you in the ballpark based on wire size, type of gas, and thickness of metal. I start off using the recommended settings and then adjust if needed.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 03-21-2007, 02:19 PM   #6
XXL
Señor Member
XXL's Avatar
Originally Posted by Slammed67 View Post
I start off using the recommended settings and then...
... turn it up 2-3x and burn the hell out of it.
XXL is offline   Reply With Quote
Old 03-21-2007, 05:02 PM   #7
Slmd92DIME
Slmd92DIME's Avatar
I turn it up as much as I can without burning through. You have to get good penetration for it to hold well.
Slmd92DIME is offline   Reply With Quote
Old 03-21-2007, 08:39 PM   #8
BK
BK Built
BK's Avatar
for sure. keep in mind, i have welded quite a bit, i was just curious. im not cocky, im going to take a day or two getting back into the groove, and getting aquainted with the welder. should be here in under a week! and i just priced my metal, 147 for a 20ft of 2x4x3/16"
Old 03-22-2007, 07:25 PM   #9
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
I was taught to weld on sheet metal, so thicker stuff is awesome, no burning through! I put her on full tilt boogie and see how she goes on some practice pieces.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 03-22-2007, 08:34 PM   #10
BK
BK Built
BK's Avatar
yeah, i was taught on like 18 guage, then 20 guage. im all ready, just need the welder, ha.
Old 03-23-2007, 01:34 AM   #11
droppedgmc
Truck Enthusiast
droppedgmc's Avatar
in running .030 wire, 4.5-speed, 6-heat on my craftsman mig. that gets a good burn onto the frame
'85 swb
droppedgmc is offline   Reply With Quote
Old 03-23-2007, 02:36 AM   #12
fireout
Fire up the cracker box if you want good penetration on your welds.
fireout is offline   Reply With Quote
Old 03-24-2007, 12:27 PM   #13
abadsvt
abadsvt's Avatar
Also something that many people aren't aware of is that when you weld a butt weld on metal that is a little thicker 1/8, 3/16 and so on is to grind down the edge to a 45* angle which creates a "V" that way when you weld you are welding both sides. That is what i did when i built my frame. The welds are very strong. Anyways good luck and i agree with everyone turn it up and if you have a 110/220 wire feed try to use the 220.
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 03-24-2007, 11:17 PM   #14
BK
BK Built
BK's Avatar
for sure. i do chamfer all my thicket metals. i will be using this thing very hot.
