Old 03-20-2007, 08:33 PM   #1
N2GMTrux
N2GMTrux's Avatar
Exclamation Inline six adding Power Brakes
I have a 1971 C-10 with Manuel Brakes. I am adding Power Brakes and have a question about where is the vacuum line connection on the manifold. If any one has a picture of which fitting the line connects too.
Thank You for your assist in this!
N2GMTrux is offline   Reply With Quote
Old 03-21-2007, 12:33 AM   #2
ks147j111928
ASE Certified Spoon Operator
ks147j111928's Avatar
Re: Inline six adding Power Brakes
My 292 has been fitted with power brakes and the vacuum line runs to the intake, check out the pic. I am going back to senor manuel brakes though, taking the 'stock/original' route with my truck. Plus I ordered the wrong stainless brake lines. duh...
Name:  valve cover (1).jpg
My six is bigger than your eight
67 K20 292 +.060" SM465 NP203 3.73s
86 4Runner, the daily on 31s
85 4Runner, the wheeler on 38s
92 x-cab truggy project for 2017... tons and 42s and V8 power
ks147j111928 is offline   Reply With Quote
Old 03-21-2007, 07:32 AM   #3
N2GMTrux
N2GMTrux's Avatar
Talking Re: Inline six adding Power Brakes
ks147j111928 ---- Thanks for the pic, I have the 250ci but it should be the same location. I really appreciate you taking the time to post the pic. Thanks
Old 03-21-2007, 08:05 AM   #4
arkracing
Weekend Warrior
Yep. My truck was a 350 with P/Brakes. I put the 250cid in it and hooked up the Vacuum line in the same place as pictured
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 03-21-2007, 09:23 AM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You'll need either a power brake air cleaner or a smaller aftermarket air cleaner too. The stock air cleaner will hit the master cylinder once you install the booster. Factory inline 6 trucks with power brakes had an offset air cleaner assembly that placed the unit over the right side of the engine. I can try and find a pic of my 292 air cleaner if you need clarification.
Old 03-22-2007, 07:55 AM   #6
N2GMTrux
N2GMTrux's Avatar
Originally Posted by Tx Firefighter View Post
You'll need either a power brake air cleaner. The stock air cleaner will hit the master cylinder once you install the booster. Factory inline 6 trucks with power brakes had an offset air cleaner assembly that placed the unit over the right side of the engine. I can try and find a pic of my 292 air cleaner if you need clarification.
Is the 292 and 250 air cleaner the same, meaning can I use a 292 off set air cleaner on my 250 in-line. And I would like to see a pic if possible. Thank You
Old 03-26-2007, 08:21 AM   #7
N2GMTrux
N2GMTrux's Avatar
Ttt
Old 03-26-2007, 09:42 AM   #8
CPNE
Resident Curmudgeon
CPNE's Avatar
250 or 292 should be the same setup. The pic below shows an oil bath setup, but the paper element set up is the same
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 03-26-2007, 12:01 PM   #9
ronh72c10
I'm planning on doing the same thing with my 6cyl C10, if you find an aftermarket air cleaner with the correct diameter base for a 1bbl I'd like to hear where you got it. I found one on ebay once but never found it again.
Ron
72 Chevy C10 (rust repaired, starting body work)
72 GMC 3/4ton 4x4
72 Chevy C20 Suburban
38 Ford Tudor Humpback Sedan (from the darkside)
67 Pontiac Parisienne
55 Studebaker Commander 2dr Hardtop (Starliner)
My Youtube channel with Video Updates!
ronh72c10 is offline   Reply With Quote
Old 03-26-2007, 01:49 PM   #10
arkracing
Weekend Warrior
I just used one that I found @ autozone. Being a cheap chinese thing - I had to "de-burr" the horn on the air cleaner to get it to fit right.
-'66 C10 Suburban
Old 03-26-2007, 06:38 PM   #11
Tx Firefighter
Here is a picture of mine off a 292. Notice how I took great pains to age it so it looks really old and original?
You can also see the vacuum hose screwed into the inlet manifold too.
Old 03-27-2007, 07:48 AM   #12
N2GMTrux
N2GMTrux's Avatar
I want to buy an original air filter like the one shown in the pic's. Thank You everyone for your help in this, I will post on the board a want to buy add.
Old 03-27-2007, 10:18 AM   #13
CPNE
Resident Curmudgeon
CPNE's Avatar
Make sure you get the support rod and threaded rod for air cleaner housing (as shown in TX's pic) and the air horn that sits on carb. My pic is an oil bath. Tx's is a paper element. The paper element is more common, but way less cool.
Old 03-27-2007, 04:39 PM   #14
N2GMTrux
N2GMTrux's Avatar
Thanks CPNE for the info: I have two of the support rods and never knew what they were for. HUH,,,,, now I know!!! I actually like your style air cleaner (oil bath) is it hard to maintain or "I mean a mess to clean up" and does it connect to the pvc port at the rear of the valve cover.
Thanks.....
Old 03-27-2007, 04:58 PM   #15
Spanky_Pete
Too many trucks? Nah...
Spanky_Pete's Avatar
Very cool, albeit weird looking setup.
I'm adding power brakes to my '67, but it's running a clifford intake and a four bbl holley. I know I'm going to have clearance issues with the air cleaner as well.
Spanky_Pete is offline   Reply With Quote
Old 03-27-2007, 08:54 PM   #16
CPNE
Resident Curmudgeon
CPNE's Avatar
Thanks.....
Make sure you get the rod that bolts to head near coil (see my pics). It is what supports the unit. It connects exactly as my pic shows. They are more maintenance and I think it's proven that a modern paper filter works better. As for mess, I've had no issues. Just use the proper weight oil and don't overfill or tip when removing.
I think the oil bath cleaner has better visual appeal and old school cache, and that one frank has for sale looks to be in good shape. The paper is far less hassle however.
Old 03-28-2007, 07:59 AM   #17
N2GMTrux
N2GMTrux's Avatar
Thank You,,,,once again for all your help.......
Old 01-22-2021, 11:06 PM   #18
1966Step
Hey Kevin,
I have 292 in my 66 that came from a school bus and I have been trying to find the original setup for a 292 option for 66. Is yours like the original from the factory? Also what type of carb do you have?
Thanks!
Rihard
1966Step is offline   Reply With Quote
