yeller
Power steering box question
How can one tell which port the high pressure hose hooks to from the power steering pump? I am assuming it is the one on the top of the pic below.
Also, I purchased both new hoses, one has the fitting on both ends (high pressure hose, supply I 'spose), the other for all intensive purposes is just a hose that is secured with hose clamps (low pressure hose, return). I assume there is a fitting I need for the low pressure hose, but I do not have one and don't remember if I pulled one off six years ago when I tore the truck apart. Can someone tell me what I need exactly so I can go about getting it?
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
Re: Power steering box question
being you have the hoses, the hose ends on the hoses are different sizes at the box.
1981 Custom Deeluxe SWB 5.3/4L60e 3.73 and Auburn. Mustang Dyno 265hp/258tq |
#3 | |
yeller
But are the two ports on the box the same size...I think they are (cannot verify unless I trek back out to the garage)? I was just wondering which one on the box was the supply port.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale Last edited by bigblock73; 03-20-2007 at 11:12 PM. |
You get what you pay for
![]() Join Date: Dec 1999
Jeff, here is an old pic of mine. You can see what you need I think.
Mike 1985 Chevy C-10 |
yeller
Thanks Mike, exactly what I needed!!
Now I just have to track down that tube for the return.
Professional Grade
Yep, pressure side is the port closest to the frame.
Did your new hose not come with the steel part?
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
#7 | |
yeller
![]() Thanks again for the help.
Professional Grade
She is definitely getting closer
How long till the first drive?
yeller
A little while yet...but not far. I may end up driving it by mid summer...we'll see.
Professional Grade
Cool, mine might hit the road again about the same time... Need something powerful enough to haul 7 - 8 quads this summer, don't think the 4.3L in the K1500 is up for it
| Bookmarks |
