Old 03-21-2007, 07:26 AM   #1
bcminimart
poly gas tank install
Whos got pictures of installing poly gas tank, bought one has no instructions in it! under frame set up on 67 panel. HELP!!!!!
bcminimart is offline   Reply With Quote
Old 03-22-2007, 12:06 AM   #2
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: poly gas tank install
I have one installed in a truck, will that help?
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 03-23-2007, 10:10 PM   #3
Big Block
Big Block
Big Block's Avatar
Did you remove your old steel tank? Do you have a new sending unit? Do you have the tank straps? It will install like a suburban or blazer tank. The panel has wood floor like suburban. I have a 72 Blazer tank out, what pictures do you need?
Big Block is offline   Reply With Quote
Old 03-26-2007, 12:39 PM   #4
bcminimart
Original tank is out,replacing with poly tank, straps and sending unit came with tank,when i put tank where old tank was the straps dont line up with any existing holes, and the straps dont secure the top of tank,they just go under it,it would allow tank to bounce around ,surely they dont expect you to mount it against the wood floor?
Old 03-29-2007, 03:07 AM   #5
oveeets
I AM LOOKING INTO DOING THE SAME SWAP OUT..I'VE HAD TO CHANGE SENDING UNIT TWICE ALREADY..IT COSTS ABOUT $70.00 FOR PART $200.00 FOR COMPLETE KIT (TANK,STRAPS,SENDING UNIT ,ETC)ALSO GONNA CUT AN ACCESS HOLE IN FLOOR BOARD ABOVE TANK FOR FUTURE ACCESS...
STEEEVO 69 BurB
oveeets is offline   Reply With Quote
Old 03-30-2007, 01:02 PM   #6
GMCPaul
I don't have any pics but I can tell you how it goes. You'll see a flange on either side of tank they rest againset the bottom of the frame overlaping the frame enough to keep it from hitting the bottom of the floor, the j-bolts get hooked in the passenger outside vertical portion of the frame with the straps at the bottom strech the straps under tank and back up towards frame on opposite side and you'll see 2 holes in the frame, since you don't have any original tank parts you'll need to get 2 bolts, washers & nuts for use on this side of the frame, other than that before doing install get your sender installed and locate all your vent hoses and your filler hose thats needed and see if they are cracked if so replace them and myself I also replace the clamps, the 1 1/4" filler hose I've gotten at farm implement stores, marine outlets and occasionally NAPA, the vent hoses are available everywhere.
Hope this helps.
GMCPaul
GMCPaul is offline   Reply With Quote
Old 03-30-2007, 01:07 PM   #7
brian10048
brian10048's Avatar
Here is the site for how to install the gas tank from the Brother's website.
http://www.brotherstrucks.com/techar...NSTALLATION%20
brian10048 is offline   Reply With Quote
