New Member
![]() Join Date: Feb 2007
what do i need?
was thinking of putting a big block in my wifes 66. what am i going to need to do to do this? putting a th350 behind it. what headers? any modifing of firewall or things like that?
any help will be welcomed. |
Re: what do i need?
mine use to have 396 in and i can tell you that that the fire wall will have to be beat in
ridin big yo 5in cpp lowerin springs in back lowered 3in in front with cut springs for now 5 lug swap and disk in front 5 lug and disk in the rear with 3.23 gears mild 350/400heads 7547weiand intake 600 Edelbrock chrome block hugger headers 2 1/2 pipes in to a x pipes super 40 flows and turn downs turbo 350 with shift kit |
![]() Join Date: Nov 2006
Re: what do i need?
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: what do i need?
When I put a 454 in my 66 Suburban, I moved the engine forward slightly so that I could run aftermarket valve covers. At the same time I converted to the 73 & up 'clam shell' type motor mounts. You can leave it in the stock location if you run stock valve covers. For headers I used Hedman 73-87 pickup full length headers.
