Old 03-21-2007, 10:59 AM   #1
waimalu
Dually 67
Has anyone put a dually rear setup under a 1967-72 wide bed. Or seen one. I like to ad dual rear wheels,because of towing a 5th wheel trailer. But rather not have to add the wider fenders. Someone said they seen one, but the inside bed fenders were wider. Thats ok ! I was thinking maybe there was a narrow dually rear that would work, or get one narrowed. Maybe use a
3/4- 1 ton single axle and put dually wheels on it. Any ideas Thanks !!!
waimalu is offline   Reply With Quote
Old 03-21-2007, 03:43 PM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: Dually 67
Without adding fenders you will have to narrow the rearend to make it work
under a stock fleet bed and that alone will involve tubbing out the inners
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 03-21-2007, 03:58 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Dually 67
a daul rear wheel axle, from a 67 - 72, can be installed with no big fenders. A little trimming and some small flairs like on an 80's dodge would be needed though. You'll have to increase the width of the tubs in the bed though, but this can be done easily.
However, this will not do a whole lot for stability. It'll help with load capacity, but IMO, with a 5th wheel, the wide stance is a VERY nice feature.
Old 03-21-2007, 04:26 PM   #4
bad_turbo
turbo enthusiast
bad_turbo's Avatar
Re: Dually 67
still think I want to do that to my '71 3/4 ton truck
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline   Reply With Quote
Old 03-21-2007, 07:19 PM   #5
waimalu
Re: Dually 67
Thanks guys for the information
Old 03-21-2007, 08:28 PM   #6
bad_turbo
turbo enthusiast
bad_turbo's Avatar
Re: Dually 67
heres a link to another member with a truck like your talking about:
http://67-72chevytrucks.com/vboard/s...ghlight=dually
Old 03-21-2007, 08:31 PM   #7
Longhorn Man
Re: Dually 67
Exactly, although, i wouldn't use a coil rear... I'd use real one ton stuff. No need to have the rear end relocate to the side every time you load up with a 5th wheel.
Old 03-23-2007, 10:19 AM   #8
Americanrider
Re: Dually 67
Can't remeber where I pulled this pic, but it's a Cab & Chassie dually rear.
Americanrider is offline   Reply With Quote
