Old 03-21-2007, 03:10 PM   #1
Pl4yboy
Freeeeee Mason...
Pl4yboy's Avatar
Wheels?
I'm looking at buying some 22" wheels for my 69 c/10. Brakes, bolt pattern, and everything is stock. Would the Eagle Series 025 fit? What offset and bolt pattern would I need? Backspacing?
Pl4yboy is offline   Reply With Quote
Old 03-21-2007, 08:15 PM   #2
Pl4yboy
Freeeeee Mason...
Pl4yboy's Avatar
Re: Wheels?
Bump...
Old 03-21-2007, 08:47 PM   #3
bs25j
bs25j's Avatar
Re: Wheels?
Ive got 22x9.5 with 6 in backspace or 20mm offset. They fit good up front but I have 73+ A arms and spindles and its a C20. I dont know if that makes a difference. The rear tucks a little more than the front but I think it still looks good.
1968 C20 Custom Camper
bs25j is offline   Reply With Quote
Old 03-21-2007, 09:20 PM   #4
Pl4yboy
Freeeeee Mason...
Pl4yboy's Avatar
Re: Wheels?
They come in 14 and 40 mm offests... so I should go with 14 I guess?I dont really mind how they tuck... I just want them to not rub.
Old 03-21-2007, 10:11 PM   #5
bs25j
bs25j's Avatar
Re: Wheels?
Ya 14mm sounds better.. From what I've seen 10 to 20 mm on a 9.5 in wheel works good.
Here's what mine look like with 285/45 toyo proxes and a 2/4 drop.
Old 03-21-2007, 11:58 PM   #6
Pl4yboy
Freeeeee Mason...
Pl4yboy's Avatar
Re: Wheels?
I don't think I'll be doing any dropping right away. Maybe some drop springs later on. You've had no rubbing issues? I really hope not! I'm not sure if i want to go with a 45 or a 40 yet either.
Old 03-22-2007, 12:02 AM   #7
bs25j
bs25j's Avatar
Re: Wheels?
I havnt drove it yet. I had 35's on it at first but I wanted to have a little more tire..I turned it lock to lock and nothing touches. I think I might eventually raise it to stock height to make sure though.
Old 03-22-2007, 12:04 AM   #8
Pl4yboy
Freeeeee Mason...
Pl4yboy's Avatar
Re: Wheels?
Thanks tons! You could probably fit the back if you added a spacer.
