drive shafts
well i got the front springs in my truck and the 3/4 ton rear in and i went to see how short my drive shaft is now . i noticed that the drive line angle was a little extream i was wondering what everyone is runing to compensate for this ?
1970 k/5 blazer--> money pit - 14bolt dana 44 350 sm465/205 36 14.50 16 tires 1972 nova plane jane 6 clyinder might sell might keep dont know 2004 chevy s-10 crewcab zr5 sold 1985 c20 chevy long bed , beater , on its way to a better place in pa from what the dmv told me 2010 kia forte koup 2.4 sx -over the river and threw the woods to the total lot it went . 1999 k1500 suburban 350 vortec 4l60e leather land yacht . |
Re: drive shafts
Your post is unclear, which drive shaft are you talking about?
Re: drive shafts
sorry i was typeing too fast to realize i didnt mention witch drive shaft . i was talking about the front one .
Re: drive shafts
I've heard of clocking the transfer case or pivoting the axle upward. Either requires a bit of work underneath.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
Re: drive shafts
Do you have pics?
I'm running an 8" lift and the front shaft angle isn't so bad. Wonder why yours might be. ![]() Here's a couple pics showing how mine sits, the first ones are of the "old" shaft and the larger shaft is what I'm currently running. It's a one ton drive shaft with a 12" slip, 1430 joints and it has a different flange @ the t-case than the other one does. Last edited by vtblazer; 03-23-2007 at 03:18 PM. |
K5Camper
![]() Join Date: Mar 2004
Re: drive shafts
Be careful on shimming the front axle to get better driveline angles. If you shim the axle to point the pinion up to the t-case for better angles, your caster setting will get worse. To correct driveline angles without impacting castor, you have to cut off the inner "C"s of your axle dial in the correct change for the driveline angles and then reweld your inner c's back on with the correct castor value. Meaning it's a ton of work and if you aren't precise on the measurements, the axle could be put way out of adjustment for either issue.
Rob Z. 1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP 1991 K5 8.1L/NV4500/241/D44/14b FWC Camper |
